Hood Vents
JESFromASC
Anderson SC
2018 Type R, 2015 Silverado, 2007 Rabbit
Now that's more like it!
Put me on the wait list.
Or let me know where I can buy one.
I'll take a factory scoop replacement in a heartbeat.
late camaro
Shawn
Central Ohio
68 Nova SS, 01 S2000, 15 Camaro SS/1LE, 18 Civic Type R
I like the factory scoop replacement, just need to investigate lower profile fasteners. Any reduction of engine temps?
spyder57
LA
ABP CTR
We have some vents sets being cut right now, our own design. We 3D scanned the hood top and bottom to fit the vents perfectly, and used CAD airflow data for design. Ours are primarily designed for true track enthusiasts and have a panel that replaces the stock scoop, as well as 3 other panels to properly open as much of the hood as possible. They will be $295 a set in a raw aluminum and will include support strips for the 3 larger vents to stiffen them, on the underside, as well as hardware to mount the scoop replacement panel. The other 3 can be attached with small bolts, rivets, etc, your choice. Attached are some pics of the full design as they lay out on the hood as well as some of our hood with the scoop replacement. We are making 4 sets initially.
This looks like a fantastic option. Curious to see what it looks like with the other 3 attached. Would also be great to get some actual data of temps compared without the vents.
I don't know why USR is so underappreciated on this forum and facebook. You guys have the most functional equipment for actual racing.
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
That hood scoop vent replacement is actually a decent idea. Rain guards would be a nice idea as well IMO. Though it would lower the effectiveness of the design.
JESFromASC
Anderson SC
Any reason you couldn't swap the factory "scoop" and this one between track and daily driver?
And - the grill of your car is a giant screened hole you are just adding another one?
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
You still need to cut an opening underneath the scoop on the factory hood. Otherwise, the vent is useless. I’d get a salvaged factory hood to do the operation and keep the mint hood for later (resale?).
Honda Civic 10th gen Hood Vents C9E6BDF8-D7C3-4C99-8890-534A60332131
Hoobastnk90
Jeff
STL
2019 Honda Civic Type R
I LOVE IT! Is it easy enough to swap out for a track day then swap the other back?
PowerPerLiter
Specific Output
Midwest
Any pics under the hood? I want to see if there any cuts on the bracing
Couldnt something be made that would be direct replacement without cutting the hood?. Remove gutters and bolt the new piece in. Should extract just as well as it fed only reversing the design flow.
PowerPerLiter
Specific Output
Midwest
On second thought that may not be far enough forward on the hood to extract so maybe not....
TypeRNY
Scott
Long Island, New York
Id also be in for scoop replacement vent. Do you think I would encounter any problems with water if I daily it?
tinyman392
Marcus
Illinois
If you can get air flow from the grill to flow over the engine and out through the vent it may be able to do its job cooling.
late camaro
Shawn
Central Ohio
It is easy to see the heat waves escaping the vent on a Camaro 1LE hood, can you see them with the replacement hood vent?
Kekela98a
New York
2019 CTR
Still no pics of the Underhood on the tracksport vents. Why is this such a hard request.
Night Fury
Chicago
Black Type R
Have you got pics of whole kit installed?
