Ruskee
So I just purchased a 2018 Si. I already own FlashPro (taken off the EX-T I had before). I've heard the Si clutch is known to be very weak. Eventually I plan to upgrade it, but not looking to do that right away. Is there an OTS map that will give me all the other benefits of a tune (eliminate rev hang, launch control, full throttle shifting, better response, etc.) while keeping the same power level? I'm okay with the stock power for now, but I really don't like the rev hang, and I just want the car to feel a bit less "nerfed down" if that makes sense. Eventually I'll save up for a clutch job and run the +6 psi map for as long as I can until the clutch starts slipping and it's time to install an FX350, but for now I want a good stock power tune. Or maybe like +3 psi tune if that doesn't cause significantly faster clutch wear. Let me know if there's a preset map for this, or if there is a safe way to modify an existing map to do this (without compromising those other features mentioned earlier). Thanks
TL;DR
How can I tune my Si with FlashPro to get all the features and benefits of a tune without enough extra power to cause premature clutch wear and slippage?
TL;DR
