Hondata Map with full bolt on recommendation?
Chi_The_Process
Minneapolis
2019 Honda Civic Type R
Hi Guys,
I finally caved in a purchased Hondata. I jail broke it this morning and I’ve been reading through the calibrations for my mods. Nothing seems to fix what I’m looking for. I will be getting a custom DYNO soon. I don’t to over boost and max out my fuel pump.
I have access to 93 octane at all time
mods:
PRL HVI
PRL Intercooler with charge pipes
Rv6 P catted downpipe
27 WON full exhaust (including front pipe)
opt 1: 93 octane PRL downpipe intercooler
Opt 2: 93 with full race exhaust
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
93 octane PRL DP/IC. Intakes and exhausts don't change anywhere near as much as downpipe and intercooler and that Full Race tune isn't meant for your combination of parts anyways, even though it's the same type of parts.
kefi
Central Florida
fk8.clinic
2018 Type R
Wait sorry, you don't have an intercooler yet. In that case, only run the 93 high flow cat map. You should get an intercooler ASAP, though.
Chi_The_Process
Chi_The_Process
Minneapolis
  • #4
Sorry my phone accidentally deleted it.
kefi
Central Florida
fk8.clinic
2018 Type R
In that case, 93 PRL DP+IC basemap all the way, with some minor self-adjustments to air charge limits if need be. I'm more than happy to check your datalogs to make sure your engine is happy with the combo.
Petrolicious
Justin
Delaware, USA
2019 CTR, 2019 Lexus RX 350 F Sport, 2017 Golf R
What exact changes are Hondata making with the DP+IC mapping?
kefi
Central Florida
fk8.clinic
2018 Type R
I compared all of Hondata's maps here.
To answer your question though, it depends if you're on 91 or 93. Over the no-parts basemaps, it's mostly ignition increases and changing the air charge limit very slightly (down for 91, up for 93). For whatever reason, they removed the cam/turbo ratio changes that were present in the individual IC/DP maps. I put those changes back into my custom tune.
ayau
Subaru
@Chi_The_Process, what a small world. I'm in Minneapolis too. I have Hondata and am pretty familiar with it. Wouldn't call myself an expert but I'm pretty comfortable reading logs. If you need help in person, feel free to shoot me a message.
Chi_The_Process
Chi_The_Process
Minneapolis
  • #9
I sent you a PM thank you
ayau
Subaru
Few things...
Hondata FK8 tuning notes:
https://www.hondata.com/help/flashpro/fk2_fk2_notes.htm?zoom_highlightsub=fk8+notes
PRL HVI:
PRL says it doesn't require a tune. I assume it uses similar MAF housing compared to the factory intake. Factory ECU will compensate for small changes. I would still verify MAF is properly scaled to the intake. You'll need to do about a 15 minute drive log. See procedure below. I would assume your tuner will.
Here's a tutorial:
https://www.hondata.com/tech-tuning-boost-afm
PRL Intercooler with charge pipes:
Intercoolers technically don't need a tune. It's just making the air cooler. Imagine driving when it's 100F vs 32F. Same effect. You can run more aggressive timing with cooler air without getting knock.
Rv6 P catted downpipe:
This will require a tune.
27 WON full exhaust (including front pipe):
Most likely won't need a tune but hard to know for sure since the turbo just became more efficient with the catted downpipe. Need to look at logs.
So it looks like the closest base map with your hardware is the '91/93 octane, high flow cat'. You may not get the most of your intercooler, but start with that tune first.
I would perform 2 logs:
1. Do a 4th gear pull wide open throttle from 2-7k RPM. Press datalog, floor it to redline, press datalog again to stop recording. You'll get to about 112mph, so you need plenty of space. Do a 3rd gear pull if you don't have space. 4th gear is ideal because there shouldn't be wheel spin.
2. Do a spirited drive log for about 15-20 minutes. This is to see if the intake scaling is appropriate.
Most importantly, which tuner are you going with?
ayau
Subaru
I was under the assumption that Hondata used the following terminology:
downpipe: catless downpipe "race"
high flow cat: catted downpipe "street"
It looks like PRL makes both a catted and non-catted downpipe. I want to say Hondata created the tune with a catless dp. I think PRL created the catted dp more recently?
ayau
Subaru
Anyway, most tuners should be able to email you a base map to use. If your intention is to get your car tuned, I would run the ' 91/93 octane, high flow cat' tune and stay off the turbo until you get your tune done just to be safe.
cassidy1969
Jerry Cassidy
Porter TX
2017 Civic Type R
If you are running the 93 octane tune should you check the box with 93 and 10% ethanol since most gas has ethanol or 93 octane with no ethanol? I wasn’t sure so I have been running 93 with no ethanol box checked. Thanks in advance for information.
ayau
Subaru
Check it because pretty much all stations have 10% ethanol. Your fuel trims will be better.
Matthew
St. Louis
Hi Guys,
mods:
PRL HVI
What tune did you end up running, and having any issues? I got the RV6 catted as well, and plan on getting an intercooler soon, so have been trying to figure out what tune I can use from the OTS selection. Once I get the intercooler, I'll be pretty close to FBO without the PRL charge pipe, so I may just end up going custom, but want to be able to run a OTS tune until then.
