Don't count on it. They locked the option to their own fuel pump and it's needs a code to unlock the feature. It was released yesterday though. You'll be able to get full e85 on a tune.How does this compare with 4 piston fuel pump? Any plan to add support for their pump? Will be good to mix match if their pump is bigger. @Hondata
Hey Hondata, I like your dyno charts, but unfortunately there are some countries that don't even have ethanol fuels(like mine?).In addition to the fuel system upgrade, consider these other unique advantages:
- Flex Fuel, for a lot more power
- Traction control to so you can put that power to the ground
Thank you for your quick reply. Sorry, meant the Hondata Fuel System... Did you guys by any chance use a turbo blanket &/or Ceramic coating for other exhaust parts when measuring the dyno numbers?We prefer to refer to our offering as a fuel system - as it is a number of parts all working together.
This is the minimum you would make. 93 will make more.
That would be awesome. Thank you and looking forward to those posts! Thanks again for your replies.We prefer to refer to our offering as a fuel system - as it is a number of parts all working together.
The alcohol is a high octane fuel, so the tuning is more aggressive. Direct injection of a high percentage alcohol lowers the in cylinder temperatures - an in cylinder intercooler.
We have a few customers running water meth. We'll share some of their results in a future post.
This is the minimum you would make. 93 will make more. With a turbo upgrade 400-450.
ive looked in my area!! No verified installers, I was then instructed to use @hondatas vendor list , so i started with the places closes to me. Kept getting turned down or they had no clue what it was. Until I contacted Ike’s Honda in Illinois , it’s the only Honda dealership I know even quoting a price for install at 11.2 billed hours & well over 1500$ plus the cost of flashpro. something unfortunately doesn’t feel right about that. So any shops we can compile a list of , or install cost , will help every member!! I was hoping Hondata would chime inn. I’m sure they will at any minuteYou should look around your area to see if any Honda performance shops that can do it. That’s what I’m doing found a shop 900$ to install the fuel system, prl flex fuel kit, and prl charge pipes.
