Hondata Flex Fuel upgrade - 265 hp and 285 lb-ft on a stock Si
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
Thanks DC2Turbo, ZRoger73, D-RobiMW for sharing the knowledge.
I have one more question, in this install, It looks the analyizer, or the fuel ratio gauge needs to route to interior cabin, as results, wire needs to punch thru the firewall grommet. Is there an alternate method, provided that I've already identified the ACC+12v wire under the hood to connect to the flex fuel sensor. Is there an android app such as Torque Lite, that can read OBDII data thru Bluetooth OBDII scanner, so I can monitor E85% thru my android phone only per needed basis? I believe hondata flashpro might have an android app to do that thru Bluetooth. but I try avoid to connect Hondata flashpro to the OBD2 all the time. so I am looking for 3rd party app, if it exist. Pls advise me again. thanks a million.
The generic OBD2 PID scan tools won't cover ECT2 in most cases, nor would they express it in ethanol percentage.
If you're a Hondata user, you would have to plug the FlashPro into the car and use the mobile app to read ethanol content if you're not using a converter with a display screen that's in view.
  • Like
Reactions: AC1
dc2turbo
usa
civic,teg
The mobile app actually doesnt read the ethanol content on our car. They need to update it
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
SI_honda_2k17
Can
Honda civic si
So impressive, but I'm just too concern by the long time effect on engine durability. I can't get off my mind that Honda engineer said that 205 hp is the maximum they can get off with the actual setup. I'll let you put some thousands miles to see.. ;)
IronFusion
Fred
Philadelphia, PA
2017 Civic Coupe EX-L
What is the max ethanol mixture you can run on a stock Si and Type R with Hondata and flex fuel system? Can you run a full E85 without any fuel system upgrades?
Yeah but unless u have a built setup with major changes anything beyond E30 is making no diff and just introducing more ethanol to your system.
