tunerguy13
post your experience with both to see the difference thank you
So basically you want to do zero research. Why donāt you compare and contrast the two products based off of YOUR needs/goals? You didnāt even state in your post what your plans are for your ctr!post your experience with both to see the difference thank you
lol, nope. I've used hondata (kpro and flashpro) in the past, but never used ktuner.lol...hit up @02SilverSiHB i think he has experience with both tunes.
if you check ktuner's site and compare it to hondata's site you'll see some of the differences. As said before, it also depends on what each person is going for, I guess.post your experience with both to see the difference thank you
Hondata has this capability as well. It's been in testing......I see ktuner has what I like the most..the choice in having various tunes loaded for each mode (comfort, sport, R+)
yeah, I saw a post about that. I'm sure it will be out by the time I make up my mindHondata has this capability as well. It's been in testing...
someone was messaging me that our fuel is good for 600whp...lol, I wish I knew where he got that info.tbh, we're so limited by the fuel system that if you are planning on getting it custom tuned, it probably doesn't matter which system you go with. I'd just go with w/e your tuner is familiar with.
What is better for a tune. 91 octane with no ethanol.or 94 octane with 10%~ ethanol?These type of posts are often an invitation for trolls to jump in, but I'll comment anyhow.
The FK8 ECU does not hold multiple calibrations by mode, but you can set the torque for each mode fairly easily. Our software has a couple of 'mods' which can set the torque tables to different levels, otherwise it is easy to do yourself.
Not sure if the length of time working on Bosch ECUs is relevant, but we had a FK2 since 2015, so had about 2 years before the US vehicle came along. A more relevant question would be how many FK8s we have, which is two. And by that I don't mean customers cars, but cars we own.
The fuel system limitation depends on ethanol content and octane, but it is not 600 hp. It can be as low as 360-370 lb-ft on pump gas.
94 octane with ethanol. The 10% ethanol will increase the fuel demand by about 4%, but the 3 octane bump will increase power by more than 4% so even if you reduce the air charge to keep the fuel pump happy you'll make more power. Also, the fuel pump is at maximum capacity around peak torque to the top end power is not limited by the fuel pump (currently).What is better for a tune. 91 octane with no ethanol.or 94 octane with 10%~ ethanol?
