Hondata carb legal tunes and race flashpro
spyder57
LA
ABP CTR
@spyder57 I'm still not sure how it will pan out. I would feel better if Hondata can just say Yes, we are backing up our product and you'll pass SMOG with the CARB version. We have the executive order and even though you jailbroke your ECU and you're running the CARB version it will not matter.
AUTHORITY TO FAIL VEHICLES FOR MODIFIED
SOFTWARE
• BAR-OIS regulations adopted on July 1, 2013 include
Section 3340.42.2(c)(8)
• “The vehicle's OBD system data does not match the
original equipment manufacturer (OEM) or an Air
Resources Board (ARB) exempted OBD software
configuration.”
Agreed, from the sounds of it, even the carb version is going to fail the checksum test as it CVN won't match up with the mfg version. Which means you'll get flagged for the state ref who can then potentially clear you if you can show the carb EO paperwork. That's quite a lot of hoops to jump through.
spyder57
LA
ABP CTR
@Hondata is the ecu clone option still offered? Looks like those links have disappeared on your site.
Kingamer
Kingamer
Brett
Irvine, ca
19 ctr championship white, Aegean blue 18 civic ex sedan
@spyder57 If you wanna do a clone ecu you might as well spend the same money at honda for an oem ecu programmed by the dealer so you have a record and it would cost roughly the same price
Hondata
Hondata
Torrance California
www.hondata.com
23' Type R,22' Civic Si,18' Accord 2.0T,17' FK8
Just read the executive order. Only covers type r thru 2019 model year.
It corvers all FK8s to current, and beyond that if the enissions standards are the same. The CA ARB is fairly good when it comes to allowing additional model years without re-testing as long as the emissions standards are the same and the manufacturer (us) makes the same changes.
We do not offer cloned ECUs.
We have found that the CA ARB are good to work with and they understand these type of issues, so this new rule will get sorted out eventually. It probably was the action of one person with insufficient consultation with other folks, or perhaps they wanted to implement the rule and then sort out the consequences later.
WOPSiWOT
South Carolina
2017 Civic Si Sedan
To answer the OPs original question, only the CARB flash pro has the CARB sticker, which is the thing you really need. They aren’t going in and checking tuning parameters. Only the CARB flash pro is fully locked. So even though the tunes are the same, the Race flash pro allows actual tuning and hence no sticker, no EO number, hence not passing inspection.
That does not answer the ultimate question. Which is can you just flash to stock and remove non-CARB compliant components and then be on your way.
spyder57
LA
ABP CTR
Thanks for the response, this is helpful. Disappointing that the clone ecu option is no longer available but thanks for the answer.
Deleted member 44294
In those counties you must still pass smog when buying a used car over 4 years old. Then you never have to smog again as long as you own the car. If/ when you sell you must smog. A bit of a gotcha unless you run her into the ground.
Kingamer
Kingamer
Brett
Irvine, ca
@20 Type R it almost makes it worth it moving out there ALMOST lol
Riverside is still tweaker central
JO3L
Joel
Southern California
FC1E5, NA6CE
Where is everyone putting their Carb EO stickers from their Flashpro? I read stories you can't just have it in your glovebox. It has to be affixed under the engine bay, but that is regarding bolt ons. Not sure how they want it for tunes.
I would simply place the sticker under hood in an easy to read area so the smog tech won’t miss it.
JO3L
Joel
Southern California
FC1E5, NA6CE
Under the hood or near the radiator core support seems to be most common.
Looking up the CARB EO # on ARB's website...they don't even have the 10th gens listed. I am hoping this just hasn't been updated on their website, but is updated in their Smog Station computers. Since Hondata says they had no problems testing a 2017 Si I guess I really shouldn't be worried.
I called them a couple of months ago and they had not received carb approval yet for the 20 and up
