Honda LogR
Caestus
Jeremiah
Miami Florida
19 Civic Type R
The problem with that is that changing oil viscosity would change your oil temps.
Yes and no. It will not change by that wide of a margin.
Remember 0W and 5W are nearly identical in viscosity. Anyone running 10W is just silly.
Dave B
Dave
Whitby On Canada
Corvette Z06 (sold) 2020 CW
True but going from 20 to 30 weight would increase viscosity when hot and potentially fool the computer in to thinking the oil is cooler. I would not be concerned about oil pressure when the engine is cold unless is it wildly out of whack.
Eugene_Fk8
West Covina, CA 91790
2019 civic Type R FK8, 2018 RX350 base
For Android app requires the Honda CarService app is installed and has permissions.
Problem with screen size. App is sized for the full Honda screen size. Does not allow for the Android control panel at the bottom of the Android screen. App will need to be resized to fit the Android screen size. It is not possible to remove the Android control panel at the bottom of the screen.
I have try to install Honda CarService and still the Andriod Auto wouldn't pickup the LogR, how do you did it?
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
From what I've read, you may need to go into your privacy settings on Android (I don't know where this is) and enable Honda CarService access to stuff.
seselectronics
CivicX Basic Sponsor
Alex
www.seselectronicssolutions.com
Civic type R
Doing calculations the accuracy will be within +/- 3 degrees HVAC techs have been doing this calculations on liquids for decades.
By the way. The JB4 calculates Oil Temps on the Type R the same way.
I think is a bad idea..
I would never rely in a calculation for check my ECT, oil temps or intake temps if anything goes wrong you can damaged you motor really bad.. If an AC unit fails nothing really bad will happen or expensive to fix.
Caestus
Jeremiah
Miami Florida
19 Civic Type R
I get your logic here for sure. It's slightly apples to oranges. However, it is science and math. It's not wrong.
I would like to know though.... do we actually have a water temp sensor? A thermostat just opens when it gets hit to allow the water to flow.
Caestus
Jeremiah
Miami Florida
19 Civic Type R
0W-20 is the same weight as 0W-30
seselectronics
Alex
Civic type R
Course we have water temp sensor, its located on the right side of the motor
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
Yes, there are two physical water temp sensors.
One is part 37870-RWC-A01 on the radiator outlet, ECT2.
Honda Civic 10th gen Honda LogR 1600827637958
The other is part of the water pump assembly, part 37870-RWC-A01. This measures water coming from the engine, ECT1.
Honda Civic 10th gen Honda LogR 1600827682053
dwag0588
David
Chattanooga, TN
2020 CW CTR, 2014 Mazda CX-5, 2006 NC Miata, 2018 Silverado 5.3 (work)
So has anyone actually confirmed that there is not an oil temp sensor present? Or is this just speculation based on the pre 2020 models?
I used the app for the first time yesterday dropping my kid off. It's pretty neat! I'm excited to use it for autocross to actually get some logs.
seselectronics
Alex
Civic type R
I don’t know the 2020 , but I can confirm the 17~19 does not have oil temp sensor , just oil pressure sensor and oil switch sensor it measure you have pressure or not .
kefi
Central Florida
fk8.clinic
2018 Type R
According to the Honda parts databases, there's no new sensor listed for the 2020 MY.
radekr
Poland
FK8 2018
Guys
If there is no new hardware then maybe it's enough to ask dealer to install the unit software from after lift model to the before lift model ;) android version in HC is the same. Someone with 2020 model can provide which software version have? I have 1.F197.0
Dave B
Dave
Whitby On Canada
I fear there may be some misunderstanding here. Often when oil viscosity is rated it is called weight, it is not that the actual weight of a given amount of oil varies but the viscosity does. I can assure you that any oil rated at 30 is more viscous than an oil rated at 20 and the W in a 0W-20 only refers to the oil viscosity at low temps. If the oil pressure is at least one of the factors used to determine the temperature, then changing viscosity should change the temp reading as there is no true oil temp sensor on the car. Engine builders always have to take oil viscosity into account as a thinner "weight" oil generally makes more power and flows more easily into tight bearings but may not be thick enough to protect those bearings etc. when really hot and effectively thinner. Viscosity modifiers are improving constantly such that we can now have highly functional oils that are 0W-40 but considering that Honda asks for 0W-20 as the OEM fill, I would stick with that unless I deliberately wanted to fool the computer
