whoisbarry
- Dec 11, 2019
- 0
- 1
- 0
- Germany
- Honda Civic X Hatchback
Has any of you ever dried to install a gps tracking app via HH? Any App recommendations?
A work around fix is disable blutooth and enable it back the App will update all the data immediatelyHas anyone that has installed HH Pro gotten their HondaLink app to continue to work? Mine will connect but wont transfer any data to the HL app on my phone anymore. Had to uninstall HH.
If you want to uninstall and not do the hide feature than you can just do the factory reset.Does anyone know how to uninstall Honda Hack (Pro version) and return the head unit back to factory settings? Do you have to uninstall the HH first then do a restore in that order? Thanks!
I'll go ahead and try that. I'm trying to isolate whether or not my phone connectivity issues has anything to do with Honda Hack and/or it could be that I may have a bad USB cable that goes back to the head unit. I barely have 500 miles on my R and the only mod I did to that area is the Honda Hack.If you want to uninstall and not do the hide feature than you can just do the factory reset.
Not sure if the issue is related to the latest Honda Hack release, but I read that it causes your screen to go blank.Just had to replace someone’s tuner unit and display because Honda hack was installed and inoperable. Use at your own discretion.
did you sort this out?I'll go ahead and try that. I'm trying to isolate whether or not my phone connectivity issues has anything to do with Honda Hack and/or it could be that I may have a bad USB cable that goes back to the head unit. I barely have 500 miles on my R and the only mod I did to that area is the Honda Hack.
The connectivity issue that I'm currently having is that the bottom left icon on the head unit says "Smartphone Connection" but when I click on the button, it just beeps at me. This is with phone connected and supposed to be in Apple Carplay mode. Plug/unplug of lightning cable does not recover the connection to the phone. I haven't yet used an official Iphone Cable- I should try to do that next although I doubt that's the issue. I have an Android phone that uses a USB Type C cable and the issue remains the same.
SW or HW issue- I'll need to isolate it one at at time.
I ended up uninstalling the hack completely. It was a $25 lesson learned. Went back to stock setup and never looked back.did you sort this out?
i had an issue where if my phone charged to 90% if would use fast charge, then drop to a trickle charge, the HU would think its lost connection and connection error, and when it goto 100% there was no charging at all... I "broke" fast charge by putting in an old USB2 extension cable.. 2m long one, and enabled USB debugging on my phone so its always using some power
I also installed HH pro and think its the best $25 ive spent, even if i wont use half the features
