CastorX
- Balázs
- Jul 8, 2019
- 10
- 431
- 166
- Germany
- Civic 1.5 Turbo Sport Plus
The story with that particular 1.33L (EU Yaris, EU Auris/Corolla) engine -and I might be writing about the other engines you mentioned, maybe this is the same problem- was partially that they wrote bullshit in the manuals and partially a design problem. A Hungarian internet site/group tried to find out what caused the problem with these Toyota engines and they did a fairly thorough research in the topic together with dealerships, brand independent shops and car owners. It turned out that Toyota listed up all the viscosity "classes" in the manual:I'm not familiar with the details on this particular engine's fiasco, but I know that Toyota put some fiasco piston rings in their engines around that time. Then they had a problem with repairing huge numbers of cars because of oil consumption issues.
If Toyota said the piston ring failures or increased oil consumption were due to owners using 30 or 40 weight oil instead of 20 weight, Toyota was shamelessly lying to confuse the issue and avoid responsibility.
After saying that, I have to also add that the panic about excessive oil consumption among many of the owners was much exaggerated.
Then they marked the 0w20 as "most recommended" and listed basically all oils as compatible/allowed and put ONE single sentence there saying something like 5w30 can also be used, but only for ONE oil change interval and then 0w20 must be used again. Not prohibiting the use of other oils btw. Later they say that if 10w30 (yes 10w!!!) is used and in cold weather the engine starts slowly then 0w20 or 5w30 is suggested. And even in the service manual they listed all oils above as compatible and the 0w20 as recommended. This led to the use of basically all oils. Which would have been fine but only for 15.000km max. The use of the the improper oil cause the (way too small) oil channels in the side of the piston to clog up after years of use this lead to oil consumption and also piston ring and piston damage and the coating on the side of the cylinder wall became damaged.
It also turned out that in case of the cars that used 5w30 but were regularly driven on long distances the problem did not appear or had just minimal oil consumption. The cars that they know of and were filled with 0w20 oil were basically all OK.
They actually described how that happened with the clogging up and why. They wrote something about heat transfer between the piston rings (yes, the piston rings again) and the cylinder wall and the "water-like" 0w20 oils and the longer drives with the warm 5w30 oils just caused the channels to clean up a bit/not clog up at all.
The thing is that Toyota knew what oil must be used and they even wrote it in the manual, when they mentioned that non-0w20 oil can only be used for 1 interval, but they spammed the whole "engine oil" section in the manual with unnecessary and controversial stuff.
It looks like they really should learn how to make piston rings and write manuals.
I hope that the 2.0L gasoline engine in the first gen RAV4 does not have such problems because my parents just bought one (mostly for work).
