refrigerant has shorter warranty terms IIRC. In the booksWhy are you attempting to add refrigerant to your A/C system? Is yours not cooling well and your warranty has expired?
The 2016-current Civic uses R-1234yf refrigerant which is far more expensive than the R-134a that was used from 1994-2015. R-1234yf is not commonly available and now requires a license to purchase in cylinders. If you look long enough, you can find cans of it for about $60 each compared to $6 a can for R-134a. R-1234yf systems use different fittings than R-134a systems.
My 2006 Honda Accord used R-134a. From its warranty booklet:refrigerant has shorter warranty terms IIRC. In the books
I was trying to do it myself, but now i understood that its requires a different system. I was used to those redtek jjits, do it yourself, I guess i am stuck to the dealer. Thank you.Why are you attempting to add refrigerant to your A/C system? Is yours not cooling well and your warranty has expired?
No.. they said it was a rock that hit the condenser.. not covered under warranty.Zrogers is correct.
The new refrigerates are expensive and require my EPA license to acquire. I really wish they'd made it illegal to sell these small kits too, stop all this confusion. They don't sell home top off kits for a reason.
I would not use those cheap kits from the parts store. You have no idea what is going on in the system or with pressures.
Need someone with a set of gauges and who can diagnosis. If Honda won't help anybody who can run an A/C machine can do it, damn near plug & play for a technician now a days.
We always use to warranty 3yr/36k any A/C work too. Is Honda really pulling back the warranty?
Yep.....any physical damage is?No.. they said it was a rock that hit the condenser.. not covered under warranty.
The physical components of the A/C system such as the compressor, evaporator, condensor, and lines are covered for 3/36, but the refrigerant itself is only covered for 2/24 unless refrigerant is required as part of a covered repair involving of the components covered for 3/36. In other words, if you had a very slow leak or a leak source that couldn't be identified, Honda will only pay for the cost of refrigerant for 2/24. However, if your engine had to be replaced under warranty and refrigerant had to be recovered and recharged as part of the process, it would be covered.Yep.....any physical damage is?
Not Honda's fault, I was speaking to a failure or leak not caused by physical damage.
Honda use to be 3yr/36k on AC, why I asked if they are pulling even the mechanical/warrantable stuff back.
Gotcha!The physical components of the A/C system such as the compressor, evaporator, condensor, and lines are covered for 3/36, but the refrigerant itself is only covered for 2/24 unless refrigerant is required as part of a covered repair involving of the components covered for 3/36. In other words, if you had a very slow leak or a leak source that couldn't be identified, Honda will only pay for the cost of refrigerant for 2/24. However, if your engine had to be replaced under warranty and refrigerant had to be recovered and recharged as part of the process, it would be covered.
