SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
I know there are already a multitude of threads about the Honda A/C failing, but a very likely reason for this failure is not being talked about very much, and since this may be KEY to the failures so many are having, it seems that it should warrant a new Thread.
It would seem that NOT USING your A/C regularly, is a major reason for seal leaks to develop.
Something to think about, especially during the Winter when you may not turn your A/C on that often, or if you are not using your car at all during the winter season ( R users -- take note)
I must admit I had never considered this, thinking that the less I used the A/C, the longer it would last for .. seems that is the WRONG way to think.
Also, if not using your car for any length of time, start it and run the A/C every few weeks. Maybe as often as once a week !!
Not only will this help keep the A/C seals lubricated, it will also help keep lubricated many other seals within the engine /transmission system
So, maybe a good habit to get into is to run your A/C for a few minutes, EVERY time you start the car, even if you don;t need to cool down the inside of the car.The most common source of lost refrigerant or oil in a functioning, leak-free system is at the compressor shaft seal.
This is typically the result of cars that aren’t driven on a daily basis and/or experience sporadic use. Shaft seal leaks have been known to develop with periods of inactivity as short as two weeks.
The common result is partial refrigerant loss and/or shaft seal oil leaks. It’s fairly common for someone to install a rebuilt or even new factory style compressor, only to find that the compressor shaft seal is leaking refrigerant or oil. A little-known fact about A/C compressors is that the shaft seal is kept lubricated the entire time the compressor is engaged and running.
Many factory a/c systems lose their charge when the a/c system is not being used.
This happens as an under-lubricated seal around the compressor’s crankshaft dries up and develops a leak that allows for refrigerant and/or oil to escape.
