TG-86
Have the reliability / dilution issues been addressed any for 2020? Thinking about leasing one. FWIW I live in Pittsburgh, so cold climate.
I think they did with the updated software.Have the reliability / dilution issues been addressed any for 2020? Thinking about leasing one. FWIW I live in Pittsburgh, so cold climate.
For DI engines, no need to let it idle for a long time to warm up. 30 seconds is sufficient and then just drive it slowly till reaching optimal operating temperature.So what’s the final conclusion on letting the car warm up on idle before driving it?
Ive always let my car idle for several Minutes to warm up (that’s what the salesman Mentioned for me to do - he’s owned 2 Si’s). He also mentioned you should let your car idle for a minute before shutting it off as well.
this is how I’ve driven my car for over a year. I live in south Florida where it basically never gets cold.
I read several repsonses that mentioned not letting the car warm Up. Which is the correct solution?
Also - wouldn’t an oil catch can help mitigate the issue?
I have one in mine (well I did before I put the flex fuel kit in there) and I ran mine for almost 1100 miles before draining it and I definitely noticed oil dilution. The catch can had a very strong odor of gas.
Correct, what you are primarily concerned with is oil pressure, usually after starting, when the tachometer shows its first drop off high idle, especially with 0W-20 synthetic oil, you're good to go. The first mile or so should be gentle as other things should reach operating temperature as well before you stress anything. The real object is to get the oil to it's proper operating temperature, which usually occurs after the coolant does. Highway miles are much easier on engines than around town driving. I had an 04 Miata that had lots of valve noise when started cold with the reccomended 5W-30 oil, changed to 0W-30 and it was completely quiet, even after sitting for months (didn't drive it in "salt" months) apparently the 0W got oil to the head a lot faster.For DI engines, no need to let it idle for a long time to warm up. 30 seconds is sufficient and then just drive it slowly till reaching optimal operating temperature.
I should film how I drive. It's scary-obsessed weird since I've joined this forum and have a "new" car now, hah.Sounds like this will be my new Habit of driving !
Thank you and also I live on a hill and I usually let it get to 1k what oil do you use for ur engineUsually not sitting too long idling will help reduce oil/fuel dilution. Just idling there with a DI engine on a cold start is brutal(probably on a warm operating temp engine too). I do take off after maybe several seconds from firing up the car. Get that combustion going and combust every droplet of fuel before the unburnt ones are sent down to the sump.
use quality oil and change it more frequently to prevent Premature wear failure. I change mine every 3k for cheap piece of mindYes thanks for the correction
Is there a way to prevent it ?
2020 si and my oil smells like gas HARD, it is not fixed or really a problem if you ask me with 3k oil changes2019 is not affected with the issue. Honda fixed it with software update from factory
Lmfao exactly why I chose my nicknameWow. Nice! I can feel the Earth Dreaming!
