Honda’s Oil Dilution Issue
FC1_BUILTBOOST
Reuben Zuev
Seattle, WA
2019 Honda Civic SI
Who’s Civic SI Has The Oil Dilution Issue ?
saiko21
Sai
Sacramento
2019 Civic Si Sedan (Sold) , 2005 Toyota Corolla (Sold)
2019 is not affected with the issue. Honda fixed it with software update from factory
saiko21
Sai
Sacramento
Yes thanks for the correction
Is there a way to prevent it ?
Drive longer and drive harder 🤣. You will have very little dilution effect in every DI engine. That's why oil companies are making their formula better with every new standard for oil
PhilF
Phil
South Central Pennsylvania
2020 CRV EX-L Platinum White Pearl/Ivory, 2020 CRV EX-L Crystal Black Pearl/Grey
Yes, change your oil at 5k intervals, use a GF6 certifed synthetic, use Toptier fuel and avoid short runs in cold weather. My Blackstone Labs oil analysis are showing under .5% fuel dilution using this protocol.
saiko21
Sai
Sacramento
I generally see SN plus but not GF6
Jt_theory
CTR
Southern California
2019 ABM Civic Type R
Usually not sitting too long idling will help reduce oil/fuel dilution. Just idling there with a DI engine on a cold start is brutal(probably on a warm operating temp engine too). I do take off after maybe several seconds from firing up the car. Get that combustion going and combust every droplet of fuel before the unburnt ones are sent down to the sump.
PhilF
Phil
GF-6 is the new standard, started in may, designed to mitigate a lot of the problems associated with small direct injection turbo engines, GF-6a is backwards compatible for most weight.weights, GF-6b pertains only to the 0-16 oils primarily for hybrid vehicles.
REBELXSi
Señor Member
You can't fix the inherent oil dilution of a DI engine with a simple software update. It may help but it definitely won't "cure" the design flaws of DI setups.
JT Si
JT
Willamette Valley
2018 MSM Civic Si
Yeah, well....
I use Amsoil SS, only drive trips of 20 miles or longer, minimize my cold idling time, and only use Chevron or Shell premium gas.
Yet my Horizon oil analysis still shows >5%.
FC1_BUILTBOOST
FC1_BUILTBOOST
Reuben Zuev
Seattle, WA
2019 Honda Civic SI
  • #13
Yeah, well....
How high does your level on the dip stick show ?
saiko21
Sai
Sacramento
Yeah, well....
Did you got your software updated ?
JT Si
JT
Willamette Valley
2018 MSM Civic Si
I deliberately put in 4 quarts that oil change, so it was at the top of the dipstick the whole time. So far this interval the oil level does not appear to have risen, so we will see if the dilution is any lower.
