jpmelfi
Did a little diy project so I didn't have to carry around a stupid garage door opener anymore.
Installation Instructions:
Using the picture below posted by @elvisfan48640, the connections for the CTR are as follows:
From Map light connector:
Red Wire - Pin 5
Black Wire - Pin 2
From red led light:
Gray Wire - Pin 4
Blue Wire - Pin 1
Pin 3 is not used.
For easy connections without solder:
-Posi-Tap
https://www.amazon.com/gp/product/B001MPW54G/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
-Jumper cable
https://www.amazon.com/gp/product/B00RMBC5I0/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Use 4 Posi-Tap's to tap into the corresponding wires listed above. Strip one end of each of the 4 jumper cables to connect to the other end of the 4 Posi-tap's. Use the unaltered ends of the jumper cables to connect to the corresponding pins listed above.
*the homelink unit pictured below is slightly different than that of the one taken from the 2017 Accord EX-L, but the pin connections are the same, when held in the same orientation as the unit below.*
Red Wire - Pin 5
Black Wire - Pin 2
From red led light:
Gray Wire - Pin 4
Blue Wire - Pin 1
Pin 3 is not used.
-Posi-Tap
-Jumper cable
