1.5T Hobby-man's engine thread
hobby-man
GTA
2018 Sport Touring Hatchback
So for those regulars around here who don't know yet, I lost my engine (L15BA) on Tuesday during some street datalogging for an e-tune with Derek Robinson. Here is a link to my most recent update post in @gtman's tuning survey.
In brief, I had been running for most of my tuned miles (nearly 20k km) on KTuner 21 PSI basemap and then TSP Stage 1 with a 27WON catted downpipe and Mishimoto intake. Around spring time last year (June) I decided to start working toward FBO and added on 27WON's intake with race MAF / turbo inlet pipe / FMIC. At that time I also had my TSP1 file re-scaled to use the Race MAF by Derek and we did some trouble-free datalogging. Since then due to work from home I have probably put 3k km or less on my engine with the full (- turbo) bolt ons. I probably hadn't even gone WOT since the required datalogs at that time.
Fast forward to last week, I pulled the trigger on a W1 turbo and got that installed. Other than two very quick test drives around the block, I did not drive the car with the turbo installed and obviously not hard at all. Derek and I then got the first revision of the custom tune flashed on the car and started to do datalogs. During the final datalog (WOT) is when I believe I lost my motor. Knock control started at 0.60 and rapidly hit 1.30 (the max I believe) over a single pull, and a rattle/tick noise developed from the engine. After inspection with a boroscope camera it appears cylinder #1 bent a rod and scored the cylinder wall.
To be extremely clear, nothing was wrong with the tune and nothing Derek did caused it. Revision 1 is always ultra-conservative and I believe the damage was already done before the W1 went on. Probably brewing for a while.
As things stand right now, I am looking at getting a 2020 Si (L15B7) motor from a recycler here. The plan is to do rods and pistons before putting it back in my car as I do NOT want to go through this again. I'll be using this thread to post pics/insights on the process as we go and try my best to answer any questions!
Datalogs attached via Google Drive for people who want to examine them
Ongoing list of parts:
1321X-59B-003 = Connecting rod bearings
1332X-6A0-A01 = Upper main crank bearings
1334X-6A0-A01 = Lower main crank bearings
60-309-195WK = Wavetrac L15 LSD
L15-OPG = Boundary oil pump gears
hobby-man
hobby-man
GTA
  • #2
09/02/2021
Got a couple photos from when the motor was collected at the recyclers. 2019 with 18,000 km!! Check out that VIN - genuine FC1. $1792.30 CAD taxes in for the long block. More pics to follow before the teardown.
09/21/2021
Car was broken into while at the shop!! Shattered rear passenger window and stolen airbag. Thanks a lot! 🤬
22/02/2021
Just adding the parts diagram and listings for the crank bearings for future reference. There are various sizes as you can see. OE block leans more to tighter tolerances. If building your block, you may want to move up a size (e.g. B to C) to give your crank a bit of breathing room at higher power levels
23/02/2021
Wavetrac LSD has landed. Man this thing is pretty. Can't wait to test it in the corners.
26/02/2021
Billet oil pump gears from Boundary have arrived!
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
Thanks for sharing the datalogs and the honesty about it.
mrburgerUS
Nicholai
Cincinnati, OH
2020 Civic Hatchback Sport 6MT
Joining the club! Built engines are definitely seeming to be a good option for hatches wanting to go whole hog. Currently my car is awaiting parts for a body repair, so I haven’t done much in the way of modifications to my built engine. I would definitely recommend the Saenz rods over BC, the amount of material that had to be removed even for the Saenz rods on the 2020 block seemed like a lot. Just about 10 hours with a dremel silicon carbide bit and various fiber discs to smooth it out for me. I would have a shop do this if you can, I just couldn’t find any trustworthy shops in the area and my biggest contact had a baby and fell off the earth. Also, the Saenz rods use a larger wrist pin bore, so the factory pistons will have to be replaced. I learned this the hard way, but it was an excuse to get the JE pistons!
David228cx
David
Spain
Well this concerns me a little. I'm waiting for the clutch to install that, the downpipe and W1 turbo. My car has 100K km and so far so good. I treat the engine well but I do some spirited driving and track days every once in a while.
Could anyone shed some light into the possible causes of failure? Anything relevant in the data logs?
ivanCivix
Italy
Civic 10th gen 1.5 sport
I'm following with attentions these failures, to me, if not custom tuned a downpipe could let the turbo spool too fast generating easly a good amount of torque at low rpms, where the rods are stressed.
They could have been damaged before the w1 install.
This a personal conjecture!
adc3132
IG: @break_ya_neck_fk7
Drew
Rochester, NY
2021 Boost Blue Type R
Thank you for sharing and being open about this!!
Honestly, half the reason for my recent upgrade to the R was fear of doing some damage... I believe tuning a stock car with maybe intake exhaust will have little effect if you don't push it hard. I started to really, REALLY enjoy driving my car after the Phearable tune and intake/catted DP/motor mount/exhaust and started to get more aggressive. I think in another year I would be making a similar thread, so I made the call to swap. I agree with this here:
I think you're on to something there. Even with the catted DP, I was hitting higher boost than I should, and it really came on early sometimes. You have to modulate that with your foot and I definitely wasn't the best of that especially with a CVT that likes to hold RPM below 3k if you are in D.
And this has been said other places too, this isn't new. I know personally I've seen comments from gtman about how once you get a downpipe, that's really the time you should start looking into a custom tune. There's definitely some merit to that.
hobby-man
hobby-man
GTA
  • #9
Of course. You're not gonna hear me say the usual "babied it, never WOT, always shift under 3k" bs lol. I am definitely an overall responsible owner and commute a lot in my car, but I tune and mod to make things more fun to open up.
Appreciate this insight. I want to do the motor right but also quickly as I need my car back. Fortunately the guy who I am working with is in the process of building another L15B7, but that dude had some issues and won't need it until April. So I'm basically taking the internals already on the way and we'll just place a new order for him. At this point I'm not even sure what rods they are but I think they're BC. Honestly not sure, my attention was focused on sourcing the L15B7. A machine shop will be doing all the work so I'm not overly concerned. We'll also be putting in JE pistons, standard bore to save on $$$ for not having to bore out and hone the cylinders.
It seems like you were running a meth kit?
Ah, thanks for pointing that out. Should have addressed that by bad. The meth kit was just installed like a week or two before the turbo. Similar to the W1, just ran it around a couple times to make sure it turned off/on when needed and no leaks. It was never tuned it (that was the final step of my custom tune with Derek) so there was no unsafe ignition advance or added boost. Funny enough, Derek told me that running meth without an ignition advance actually results in LOST power. But it does have the benefit of charge air cooling and knock prevention, which is the major reason why I got it in the first place. For engine protection l...o.....l.......
As I said in the tuning thread, I don't think it's possible to say exactly what happened. Could definitely have been an existing factory weakness I exposed over time. Could have slowly damaged an otherwise great motor over time with bolt-ons. All we can say right now is even on the ultra-conservative revision 1 for my custom tune, the combined weight of FBO was too much.
I don't know very much about the L15B7 (yet), but for those with the weaker base motors I'd probably suggest that an intake and flash tune is as far as you should go without custom tuning if you are concerned about longevity.
I've anecdotally heard that individually a DP, the turbo inlet, and race MAF all helped with added torque. So all 3 of those bolted on could definitely have weakened the rods before the W1 ever went on, as @ivanCivix pointed out.
hobby-man
hobby-man
GTA
  • #10
What other mods do you have? The fact you held off on the DP is probably a really good thing IMO. If you're getting tuned immediately after installing those 3 parts (minus clutch break in) I don't think you have to be TOO concerned, provided you're extremely easy on it during break in.
David228cx
David
Spain
I currently have these engine mods:
PRL intercooler
27won intake
Custom exhaust
Tsp stage 1 with Ktuner
I also made a series of chassis reinforcement mods to hold the extra power well when I mount the W1.
Rmm Perrin inserts
Tein Flex z coilovers
Lightweight wheels (2forge zf1)
Hardrace front strut bar
White line sway bars kit
Custom big brake kit
Btw, good luck on the rebuild. I'll be looking forward to see it running again :)
hobby-man
hobby-man
GTA
  • #13
Good luck on the rebuild! I’ll be following.
Thanks brother! Should be getting the L15B7 in today.
PRL intercooler
27won intake
Custom exhaust
Rmm Perrin inserts
Appreciate that! :) Really nice chassis mods btw. I feel like you are still operating within what's safe but obviously my advice is worth less these days given my bent rod LOL. Are you e-tuning with Derek or doing something local? I'd maybe suggest having a tune file ready to load up before you even start the engine with the turbo and DP. Something ultra conservative and boost limited. Then you can at least drive around a bit to break in the clutch and you're not rolling around FBO on TSP stage 1, which is what I did. Just thinking out loud though...
David228cx
David
Spain
My plan is to get the base map to get the logs as soon as it's installed. I hope that's safe enough. I've seen people with the L15BA reach 300hp at the crank safely around here. So let's hope it goes well.
Yes, Id get Drob to e-tune it.
hobby-man
hobby-man
GTA
  • #15
Nice, I think driving around for a long time with the downpipe contributed to my failure. Please keep us updated but I'm sure things will be fine for you!
