High Speed Stability is Off After Flat Tire?
davemarco
davemarco
So an update on this: I've had two alignments, got a new factory wheel and tire, and had my summer tires rebalanced and remounted. Even with the summer tires on, I'm still seeing the car pull gently to the right when I step on the gas. It's an annoyance when cruising, but when driving aggressively, it feels dangerously unpredictable. The car straightens out as a let up off the throttle, and pulls lightly to the right when I step down.
I have an appointment on Monday to have the tie rod, lower control arm, and associated bushings looked over. Even if they find nothing, I may just have them replaced them for piece of mind anyway.
How likely is it that a high speed impact strong enough to blow out the tire could've also damaged a tie rod or control arm (or bushing)? Anything else that I should have them look at? Wheel bearings? Upper control arms (do we have upper control arms)?
davemarco
davemarco
That sucks man, keep us informed. Have you had anyone else drive and confirm your findings?
Just the first Honda tech that looked at it. Hopefully this guy on Monday notices it and finds the problem.
Nanook
JP
Chester, VA
2009 Accord, 2018 Pilot, 2017 Si, 2018 CTR
This might be a stupid question, but do you have all new summer tires or are you running one "new" tire and three older ones? I ask because I ended up with a brand new tire on the front with the three other tires having around 3600 miles on them because of almost the exact same situation you described. I encountered a little of what you're talking about. I rotated my tires, so the newer one is on the back, and I don't have the pull you describe anymore.
davemarco
davemarco
No worries. The other 3 tires are only a couple of months old, and the tread on the front tires and rear tires both match (8/32's in both fronts, 7.5/32's in both rears). The issue also occurs with my all season tires/wheels, so I've ruled tires/wheels out at this time.
JoYu
Ca
2019 type R
Cars will pull slightly to the right because of the crown in the road. Is the shake gone now? Good luck finding the problem
davemarco
davemarco
Shake is gone. I think that what I notice most after the impact is that it even if I angle the steering wheel a couple of degrees to the left of center, when I hit the throttle, it starts tugging to the right. If I let up off the throttle the nose visibly shifts back towards the left.
idragmazda
CT
Fk8
Any update man? I’m having same issue but opposite direction. Thanks
davemarco
davemarco
After a look, the Honda dealer didn't see anything. They said that they shifted the centering of the steering wheel slightly to the left to better account for the crowning of the road.
Maybe I'm just nuts? I don't know what to believe anymore.
idragmazda
CT
Fk8
Did this help? This is what my dealer is telling me to do as well lol
davemarco
davemarco
Maybe? I'm unsure. The issue is really subtle - after such a major impact to the wheel, I'm paying really close attention to things. As such, I'm not sure what's actually a new problem, and what predates the accident.
At this point the only thing that I can think of doing is to start replacing the suspension components in that corner, and I'd rather not do that on a 6 month old car.
Stupid debris in the stupid highway. :(
krees
Mountains of Central PA
2018 Civic Type R & 2020 Ridgeline BE
I hear you on the road debris. Within my first 6 months of ownership (~3k miles), my entire front end got replaced due to a tire tread in the fast lane on the highway. It sucks indeed. Hope you get it sorted soon.
