redline
Saw this post on the hondata forums and was wondering if anyone else has looked into the high pressure fuel pump from the nsx?
"Have you guys looked into the NSX high pressure fuel pump? I confirmed that it will bolt up to a K20C1 engine. The low pressure inlet line needs to be clocked slightly and the high pressure will probably have to be bent.
Not sure about flow rates of each one. If you have a way to test them I'd be happy to drop it off to you."
