arnoldo
- Arnoldo
- Nov 28, 2019
- 19
- 560
- 398
- Jakarta, Indonesia
- 2019 Honda Civic Hatchback
Car: Honda Civic 1.5T CVT Hatchback
Background
I've been using Hondata Flashpro for a little over 5 months now. I purchased the device from one of reputable tuners in my country. He mentioned that many tuned Civic Gen.10 in my country experienced connecting rod damage due to excessive boost pressure. He defined excessive as in 21 PSI and higher. He stated that he would tune my Flashpro with no change in boost but only fuel tuning. Unfortunately, he wasn't entirely honest as he only flashed +6 PSI High Octane basemap.
I've been trying to learn how to tune my car since then but very confused because there were may parameters need to look at.
I decided to purchased TSP Stage-1 Tune for Non-SI. I thought this is a safe canned tune that I could rely on because many Civic X member use this tune, either in KTuner or Flashpro platform.
BUT..... There is no other country has tuned Civic X with damaged conrod due to excessive boost (21 PSI and higher) like in my country.
I tried to read TSP Stage-1 Tune binary file and found some worrying factors. First, peak boost is 23 PSI, & second, torque limit from 3,500 RPM was set higher than Hondata safe threshold of 250 Nm.
I know there is still no hard facts/evidence that proofs 250 nm is really maximum torque that CVT can handle but no other member from other countries but my country heard about tuned Civic X with damaged conrod.
So, better safe than sorry, I try to learn how to tune the basic parts such as AFM, Boost pressure, and Torque limit.
Environment:
19 PSI Tune Version 1.01
Basemap used : +3 PSI Hondata basemap
Modifications Selected:
Changes made:
I enjoy the tune so far and I think the datalog show decent result but I just have a feeling that the tune still can be optimized as I didn't touch fuel and ignition tuning.
I know that Hondata Flashpro platform for Civic 1.5T is not as popular as Civic but I do hope someone in Civic X forum who can help provide insights on what I could still improve from this 19 PSI tune.
I hope this threat could bring some excitement back to Hondata Flashpro section and could also be use as learning materials for both Flashpro and KTuner users.
Looking forward for your feedback.
Background
Environment:
- Ambient Temperature: 26 Celcius to 35 Celcius
- Humidity : 72% - 83%
- Optimized Turbo Response
- Improved Throttle Response
Changes made:
- Closed Loop : Select "Use MAP to determine WOT"
- AFM : AFM adjusted so that my S.Trim is within spec. Currently, it is better than S.Trim when I was using Hondata +3 PSI Basemap calibration.
- Boost Pressure : Conservative boost from 500 - 2500 RPM. Boost start to pick up from 2750 RPM and gradually reached approx. 19,2 PSI at 5500 RPM. Boost decrease starting 6000 RPM
- Torque Limit: Torque limit is set at 240 Nm from 500 to 1750 RPM, went up to 245 at 2000 RPM. Torque limit is set at 250 Nm from 2250 to 6000 RPM, 245 at 6500 RPM, and 240 at 7000 RPM.
