The Driver's side is lower than the passenger side. But, they do illuminate the middle very well. I heard that the shaking is normal and expected? I'm going to check and make sure they're seated correctly. Hopefully that fixes the issue.Im having the same issue and it bothers me but I didn't think it was something that could be fixed, if someone does have a fix please share!
Also is it just me or do both of your headlights point to the right as well? My driver headlight shines at the center of my lane when i'm driving and my passenger headlight shines on the line to my right or in the lane next to me.
I've taken mine out and tried to re seat them multiple times and they still shake and aren't correctly alignedThe Driver's side is lower than the passenger side. But, they do illuminate the middle very well. I heard that the shaking is normal and expected? I'm going to check and make sure they're seated correctly. Hopefully that fixes the issue.
Also, I got the 5500k color, but to me, it has a green/yellow hue to it on the sides of the road. I might swap them out for 4500k to get a more stock look.
Here is a bad picture that I took quickly. You can see the cut off is pretty good on mine. Do you happen to have a picture of yours? Maybe you can warranty them and get a new pair?I've taken mine out and tried to re seat them multiple times and they still shake and aren't correctly aligned
I don't have a photo of mine, but its hard to see them being not straight in a photo![]()
The top pic I'm at an angle and not straight into the wall — didn't have enough space lol. Also, they don't look as "green" in the pictures as they do in person.
My understanding is that HID bulbs do a color-shift (Upward in kelvin) after a 100 or so hours of use. Not sure how much though. Maybe someone can confirm if that's true.do they have a break in period for color temp? I have the 5500k and it doesn't really match my drl/fogs, was hoping they would.
Did you contact the place you got them from and ask about this?I've taken mine out and tried to re seat them multiple times and they still shake and aren't correctly aligned
Any issues with 55watt? Looks good. Over heat issues?
No issues so far. I went with DDM's middle tier HID Plus kit. Very happy with them. Besides my daily commute to and from work during the day, the longest run time I've had with them on was a 3 hour trip. No overheating from what I can tell.Any issues with 55watt? Looks good. Over heat issues?
