sbace_hamb
- Shane
- Nov 22, 2023
- 9
- 478
- 303
- Illinois
- 2018 Civic FK7 EX
Bought some rear shocks off of rockauto and went to replace them with my day off yesterday. Last lugnut I went to remove on the rear driver's side wheel was stuck pretty good. I sprayed some penetrating oil and let that soak for a bit, then worked what I could, and then repeated. During one of my cranks, there was a loud pop or snap and the lug and stud started free spinning together. So here's where I'm at:
I attempted adding positive pressure to the nut by using a pry between the wheel and suspension, and then quick bursts with an impact. This seemed like it could work, but I was just one dude sitting in my garage with a floor jack, so I didn't have a lot of room or leverage to work with.
With the brake shield in the way and not a lot of clearance to work with, I couldn't get a visual on the back of the hub/stud, nor do I really know if our studs are visible from the back. There's a bit of back-and-forth wiggle, so the stud should be accessible either between the wheel and the hub or from the back of the hub, if they can be accessed that way.
Is it feasible/is there any foreseeable issue if I just decide to crank down and out on the wheel and attempt to snap the stud? Or any other suggestions if that's a bad idea? Otherwise, I'm just going to have to hand it over to my mechanic and let them at it. It would just be nice if I could get this resolved without paying the current labor rates.
