gearhead
- Greg
- Jun 28, 2020
- 9
- 51
- 33
- 21702
- CTR
WEDSSPORT RN-05M 18X9.0 +50
GRAMLIGHTS 57CR 18X9.5 +38
Choosing the right wheel / tire package is EXHAUSTING! With so many options, it's tough to get it right.
- I'd like to stick with a "gloss black" finish - same as the 20" OEM look. (Feel free to suggest other Gloss Black, lightweight wheels, in this price range)
- Can I use the OEM CTR gloss black center caps with these wheels?
- I need more rubber on the sidewall. Potholes are maddening. Most of you recommend going with an 18" set-up. I'll be fitting 255/40/18 tires as this size looks to be closest to the OEM 245/30/20 size. https://tiresize.com/comparison/
- I'll be running stock suspension. No lowering, etc. I hope that I will not lose too much of the lighting fast turn in and CTR handling characteristics going with the 255/40/18 tire size.
- I imagine the WedsSports +50 offset, close to the +60 OEM/factory CTR offset, may keep handling characteristics closest to original.
- WedsSports weigh just 20.2 pounds (semi-forged? "Advanced Metal Forming")... the Gram Lights 57CR are cast (yes?). I'm not sure what the 57CR weighs.
- WedSports run about $100 more each. $485 vs. $385 ish.
Lug Nut recommendations are appreciated!
Thank you all in advance for your insight..
