DaiLo
- Aug 26, 2019
- 24
- 132
- 102
- Canada
- 19 Civic Hatchback Sport
- Vehicle Showcase
- 1
So before I do anything crazy, I want to understand exactly how these work and what is within the bounds of safety, specifically with a CVT. Although I am going to buy the TSP stage 1 tune really soon, I am currently using a dual 21/eco tune with quick adjustments and early spool turned up.
1. With BBG in a CVT, obviously there are no "gears". Even with the simulated shifts, they're not defined gears. So how does 1st, 2nd, 3rd, etc. work?
2. There are two BBG options. Let's say "16 PSI boost level" and "16 PSI boost level with ramp". If I chose without ramp, does that mean it will go full boost at that "gear" all the time? Wouldn't I always want a ramp for smooth boost?
3. I am primarily interested in this to extend the longevity of the CVT. At the moment, all the BBG are "custom boost level" so I don't know what they actually are set at. What are some values I should set 1st and/or 2nd at to be slightly less than the current tune? I dont want to kill that low end torque either though.
4. Advanced VSA: I want to play around with this because on stock tires and the current tune, I spin my wheels on launch. So if I understand correctly, the engine cuts timing when it feels like its losing traction to attempt to get the tires to grip again. So this part confuses me a lot and I'm a noob so ELI5 please. what exactly are the differences (feel-wise) between all the VSA control strategy settings. The more aggressive the ignition pullback, the less wheel spin will happen right? When should you go with a lighter ignition pullback over a more aggressive one or vice versa? Pros and cons of going too aggressive or light?
5. Are these all safe? This applies to both the CVT itself as well as just daily driving. I know it messes around with the traction control and I live in Canada where there's snow, ice and rain to deal with. I don't want to do something so drastic to the traction control where I will spin out if I hit a patch of ice. I just want less wheel spin when I aggressively launch.
Thanks. Also tagging @gtman because when it comes to Ktuner I always appreciate your input and I know you have a CVT too.
