If he has the EX model he wouldn't have a turbo engine... Unless it is different in Canada?Take it off Eco mode and watch the lights. If you have the full display, you can watch the turbo gauge. It shouldn't go higher than 2 or 3 bars under 'sedate' driving conditions. Otherwise, I wouldn't expect the mileage to be that low even with city driving. I can't think of any Canadian city that would be hilly or traffic-filled enough for it to even come close.
Why is Eco mode bad????Take it off Eco mode and watch the lights. If you have the full display, you can watch the turbo gauge. It shouldn't go higher than 2 or 3 bars under 'sedate' driving conditions. Otherwise, I wouldn't expect the mileage to be that low even with city driving. I can't think of any Canadian city that would be hilly or traffic-filled enough for it to even come close.
ECON isn't bad, per se. But my own experience is that it doesn't really make that much of a difference in mixed driving. I only saw about a +1 mpg gain between ECON and regular Drive modes. Now put this baby is Sport mode? Yeah, it dropped like -5 mpg on the same route. ECON mode seems to cap the turbo boost and cuts the AC more frequently to help improve fuel efficiency among other things. Perhaps on all city driving the ECON might be more effective since there's a lot of starting and stopping.Why is Eco mode bad????
Good to know, thanks. I'm looking gorward to using sport modeECON isn't bad, per se. But my own experience is that it doesn't really make that much of a difference in mixed driving. I only saw about a +1 mpg gain between ECON and regular Drive modes. Now put this baby is Sport mode? Yeah, it dropped like -5 mpg on the same route. ECON mode seems to cap the turbo boost and cuts the AC more frequently to help improve fuel efficiency among other things. Perhaps on all city driving the ECON might be more effective since there's a lot of starting and stopping.
Here's an excerpt from TorqueNews.com about what ECON mode does (keep in mind I think they're referring to the 9th gen but I'm fairly certain it still works pretty much the same way):
Looking to the low displacement 4-cylinder engine, ECON works a bit differently
Here’s how ECON saves Civic drivers a few dollars when used in conjunction with the fuel-economy optimization meter front and center on the dash.
By limiting the mid-range depression movement of the drive-by-wire throttle (you can feel it fighting you) ECON mode in Civic limits fuel delivery to the throttle body. At the same time active horsepower draining features such as the air conditioner- cycling changes.
You may note the air conditioning compressor coming on and shutting off more often than usual. In hot weather it is recommended that you don’t run continuously in ECON mode. Your cab temperature will run hotter than usual.
In CVT equipped models and older conventional automatic transmission equipped Civic, ECON mode modifies the shift pattern for fuel efficiency. You may notice this change when driving up a grade at speed. Your Civic will not downshift as readily when compared to selected normal or spot-mode for Civic if so equipped.
Sport mode is great around town but on the highway it seems pretty useless, IMHO. Race ya later!Good to know, thanks. I'm looking gorward to using sport mode
Eco mode isn't "bad" per se, but it cripples performance so severely, that you end up pressing harder on the gas pedal just to get to an acceptable speed within a reasonable amount of time.Why is Eco mode bad????
