- Feb 15, 2017
- 108
- 4,710
- 4,874
- USA
- 2019 Accord Sport 2.0T, 2017 Si Sedan (Sold), 2017 Sport Hatchback (Sold)
- Vehicle Showcase
- 1
Can't say I've ever seen that one before.i ran the tsp stage 1 for a long time. Didn’t get any issues from running it. If it didn’t throw a code, it could be bad gas. Plus tsp is known too lose power top end.
A knock count of 12 is basically nothing. Any significant misfire situation would report knock counts in the high hundreds if not thousands over a half hour drive. I don't know your full back story but if you aren't seeing check engine lights (either blinking on constantly on) regarding a misfire situation it's probably not worth worrying about.I have a very slight misfire on cylinder 3. I've swapped coil packs, still there. I'm changing plugs next.
The interesting thing on my car is that I'm getting the k.counts when I lift off the throttle (to shift) at lower RPMS. Sometime I get zero counts on a half hour drive, other times up to 12.
I did an interesting experiment after I found what RPM this was occurring. I reved the engine in neutral at 1500rpm and held it there. The k.counts were increasing as I held the rpm! I could here a slight miss in the exhaust as well. I ran a datalog to see what, if anything was going on. Ran the datalog until I hit 80 on k.count (it took a few minutes). When I looked at the log, it showed 83 counts for cyl 3... all other cylinders were fine.
What is very strange is that under throttle and hard pulls, everything is completely normal and no additional counts for cyl 3. It only happens at lower rpms and steady 1500-1800rpm (with no load)
I'll update once plugs are changed with pics. If the problem is still there then I'm seeing the beginning of an injector issue.
