tacthecat
- Feb 9, 2016
- 6
- 2,069
- 891
- Cheshire, MA
- '12 Civic Si Sedan
5th (.911) & 6th (.743) are OD.
I thought you will have to multiple with the final drive too.5th (.911) & 6th (.743) are OD.
Is the Optima GT also a 2.0 turbo? If it is manual, do you have enough torque for accelerating at 70mph/110kmh in 6th?Our Kia Optima GT in 6th at 70mph is doing aprox. 1800rpm...
Nothing seems high after having a s2000, or a 8th/9th gen SI.Maybe a bit off topic but don't you guys think the rpm in 6th gear is stupid high?
At 110 km/h (70 miles/h) I have 2500 rpm. In some countrys the legal speed on highway is 130km/h (80 miles) and at that speed I get 3000rpm. Cruising at 3000rpm is neither comfortable nor economical.
Yes! It is a 2.0 twin scroll turbo with 260 lb-ft from 1500 rpm and 245hp.Is the Optima GT also a 2.0 turbo? If it is manual, do you have enough torque for accelerating at 70mph/110kmh in 6th?
Can you explain what is actually uncomfortable about driving at a certain RPM. Do you mean because the engine is louder? Cause I really don’t have an issue with the sound of the engine at those speeds. I have more of an issue with the road noise at that speed. Not that I’m complaining, but I just think the road noise would be more annoying than engine noise. Unless you mean uncomfortable in another way..?Cruising at 3000rpm is neither comfortable nor economical.
And this car's main purpose is to be driven on a motorway at road speeds? They designed the gearbox for track use with close ratios, any other use is secondary. A higher 6th would hinder performance.Maybe a bit off topic but don't you guys think the rpm in 6th gear is stupid high?
Can you explain what is actually uncomfortable about driving at a certain RPM. Do you mean because the engine is louder? Cause I really don’t have an issue with the sound of the engine at those speeds.... Unless you mean uncomfortable in another way..?
Weeeell... let's not forget that this is a hatch with four doors and a big boot. It is not a Renault Megane RS Trophy R...And this car's main purpose is to be driven on a motorway at road speeds? They designed the gearbox for track use with close ratios, any other use is secondary. A higher 6th would hinder performance.
Only needed on the Ring. But not during tourist drives.I'm not attracted to trckbdriving but I presume you don't use the 6th gear in a race...
