Hasport Rear Engine Mount
Scarlet
Shawn
Caledonia, WI
2001 Civic LX Sedan - 1998 Civic Hatch - TBD Turbo Something - 2014 Honda Ruckus - 2017 Civic Si Coupe
Installed the 62a mount today. Anyone else notice there K count going up? Like low speeds, 1st and reverse.
That could be happening due to the increased NVH, the knock sensor is likely picking up the addition "noise".
RedFK8
17' CTR
I have the 70A installed. The NVH isn’t too bad but you definitely know it’s there when you rev it up from idle. The engine feedback under hard load and acceleration is incredible and wheelhop is minimized. I datalogged a few pulls and misc street driving and so far the ECU and ktuner hasn’t picked up any knocks even with the extra vibration.
kshawn
Matthew
Maine
2017 Civic SI
The knock count is starting to calm down as I drive with the new mount. I'm thinking this assumption is right.
kshawn
Matthew
Maine
2017 Civic SI
Update:
Knock count was related to the vacuum in my intake manifold DRINKING my water meth tank. I need a extra solenoid in my application. To stop siphoning issues.
This resulted in very RICH conditions at idle and low end/ letting off the gas. Or wherever I was at negative pressure.
I've disconnected the system and ordered the part. And adjusted my MAF a little more for the PRL race housing. Shout out to @KTuner for the support!
fkturboindo
Osmar
indonesia
Civic FK4 1.5 Turbo Hatchback
Hello, I just installed this morning. I think increase vibration and noise. how long is break in/ broken in period? Confuse about back to stock or stay use Hasport 62A. sorry for my bad english. Thank you for your help / opinion.
Honda Civic 10th gen Hasport Rear Engine Mount IMG-20200703-WA0042
Honda Civic 10th gen Hasport Rear Engine Mount IMG-20200703-WA0045
Honda Civic 10th gen Hasport Rear Engine Mount IMG-20200703-WA0040
Benster
Ben
Nova Scotia, Canada
2019 Civic HB Sport 6MT
it will take a few thousand kilometers to really break in and quiet down, however, it will settle quite a bit within the first thousand km as well. I still have mine after 35k km but it does make the car feel less refined with the mount. It also makes it so much more fun to drive and this is why I'm sticking with it. Other options are window urethane in the stock mount or a Type R RMM.
