PowerPerLiter
Specific Output
Hasport 62a. Soon to be replaced with OEM CTRWhat mount did ya get again?
Oem ctr mount better?Hasport 62a. Soon to be replaced with OEM CTR
Well better than stock si. it is a higher durometer OEM mount designed within vibration limitations and will control the torque an R makes. Should be perfect for not building a "race car".Oem ctr mount better?
Thanks for the input.Well better than stock si. it is a higher durometer OEM mount designed within vibration limitations and will control the torque an R makes. Should be perfect for not building a "race car".
I made a separate thread about the possibility of our dual mass flywheel affected by these aftermarket mounts but nobody cares.
They should all (rear torque mount replacements that is) fit all models that are manualThanks for the input.
Will ctr mount fits on sport Hatchback?
Do you have part number for ctr rmm?They should all fit all models that are manual
Edited for clarification. Only the rear mount is shared as far as I know all the other mounts will be different from 2.0 to 1.5Do you have part number for ctr rmm?
Thx
Thx
Thanks alot.
Been in process of home shopping and buying. Its on the list but may be a while. I have yet to see any other reviews on it but I am fairly certain it would be the business for those not really wanting much vibration.hows that ctr mount riding
I’ve it in mine. NVH is just barely more than stock as it's at 60 durometer (Shore A Hardness below). So it should be a step below the 62A Hasport. It requires 48 hours to fully cure.Thanks alot.
Wonder if anyone try ctr rear mount with window weld!
And does it help with the wheel hop on full lunch?I’ve it in mine. NVH is just barely more than stock as it's at 60 durometer (Shore A Hardness below). So it should be a step below the 62A Hasport. It requires 48 hours to fully cure.
I’ve never done a full launch and felt any wheel hop so can’t really comment. Tire slippage was mostly eliminated by Hondata TC.And does it help with the wheel hop on full lunch?
