Has anyone removed the Si front badge??
EdwarDallas
Edward
Dallas, Texas
2020 Civic Si
I am wanting to remove the stock red Si front badge, I am just not sure how to approach it.
Is it stuck on or screwed on from the back??
Edward
I'd have to imagine it's just taped on. If so, a hair dryer to heat it up and a sawing motion with dental floss should get it off. Use Goo Gone to remove any tape residue.
Driver56
RVA
2018 Civic SI coupe
I believe the emblem is mounted to a "SI" shaped piece of plastic in the grille, so it's not going to look great just removing the emblem. I'd recommend just purchasing a grille without the badge and installing it.
JT Si
Place
Car
I'm pretty sure the mounting plate for the Si badge is screwed onto the grille from the back. You should be able to remove the whole thing if you want.
EdwarDallas
EdwarDallas
Edward
Dallas, Texas
2020 Civic Si
Here's a picture of it from the back, I have an aftermarket grille so I dug this one out for research. 2018 coupe. Looks like you'd have a little black square, but you'd have to remove it to unscrew the emblem.
Thank you!
VTecYoSelfB4UWreckYoSelf
Kevin
2020 Civic Si Sedan Aegean Blue
Then how will they know it's an Si?
