BobbyA
- Bobby
- Nov 19, 2018
- 14
- 77
- 59
- Fredericksburg, VA
- 2018 Civic Si Coupe (PRL Stage 1, Hondata FlashPro, PRL Flex Fuel e85, HardRace Rear Mount, Megan Racing Strut Bar) Wish List: PRL Catted Downpipe, Eibach Pro Springs Kit, Seibon Carbon Fiber Hood & Trunk.
Today I installed the HardRace 8722 Rear Mount. 100% Happy with the results. There is zero (0) NVH, and the shifting is so smooth now as compared to the factory mount, that it's amazing!! When the factory mount was there, I always had rough shifts in 1st and 2nd due to the slight rotational pull of the engine, that is all gone now. No more parasitic loss in HP either, at least from what was happening in that regard. Here are a couple pictures and I wanted to share that instead of removing all the fasteners from the rear plastic cover, I simply made a slit in the plastic, see pic with my finger pointing at it. This was enough to get some play and pull the rear bolt out of the mount, the rear bolt has a 17mm and the front has a 19mm head. The plastic cover is thick enough that this slit won't hurt anything. You do need to remove the aluminum bonnet, so you might as well plan for an oil change with this mod...
