Hard wiring dash cam
biosses
Japan
Civic
I don't have a volt meter. Which fuse slot I should use? I want the dash cam to turn on when i put the car in Accessory Mode. I was able to achieve this for my R3 Uiden by taking fuse slot #1. I need anther one slot for the dash cam. thanks.
Honda Civic 10th gen Hard wiring dash cam screenshot.138
Honda Civic 10th gen Hard wiring dash cam screenshot.139
biosses
Japan
Civic
I went off of this sticker on my car, used #17 since my car didn't come with CMBS. My dash cam comes on in acc mode
cool thanks. I need to look at the sticker in my car. According to the user manual, #17 has "transmission" that was why i didn't use it, but i was looking at the user manual and not the actual sticker layout in my car. Right now, i plugged it #17, which is for AC, but dash cam turns on only when the car is fully on.
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
Unless your two devices draw more than 10 amps; I believe that you could split or 'Y' your current fuse #1 supply. If you have something plugged into the accessory slot (cigarette lighter); you'd have to factor that in too.
biosses
Japan
Civic
it's a Rexing dash cam and R3 radar, probably no more than 7A together. The supplied fuses for the devices are two 5As. I thought about that, i' probably won't try stacking method though. I think there are other options, if not, i'll leave it where it is.
biosses
Japan
Civic
Civii
Los Angeles / Antelope Valley
2017 Honda Civic
https://www.amazon.com/Uniden-RDA-HDWKT-Detector-Hardwire-Button/dp/B07BBVC7JQ
#21 you referring to is on the outside fuse box, in the engine bay. I rather not mess with that by making wiring too complex, i rather use inside fuse box, more straight forward.
I think either #4 or #17 will work, depending on your car, you need to check the sticker near the interior fuse box.
I wouldn’t use anything that’s for the engine, transmission, or airbags. Try using a door lock one. Maybe the passenger door lock?
xRiCeBoYx
Josh
Las Vegas, NV
2018 Civic Sport Hatchback CVT
I thought about using the door lock. Tried using the door lock. Also tried using the power window fuse. Neither have a completed circuit unless you're locking/unlocking the door or opening/closing the windows
biosses
Japan
Civic
yeah, i stay away from those. The door lock ones, driver or passenger lock is ALWAYS on, means my dash cam will be always on.
biosses
Japan
Civic
yeah, because the door lock and door unlock have two fuses, they are not complete.
biosses
Japan
Civic
What dash cam are you using? Does it have parking mode?
I'm upgrading from Apeman 420 to Rexing V1, 3rd Gen. It does have parking mode, but i'm not planning to use it for parking mode. If you want parking mode, you need a constant power fuse. I heard the parking mode sensitivity on the Rexing V1, 3rd Gen is low. If you want parking mode, maybe look at another one.
