Hands on with TSP's Stage 1 tune for the 1.5T (non-Si)
SilverArrow
Italy
Honda Civic X 1.5 T. Sport
I changed 4/5 gas station, 95 and 100 octanes, but i have knock control very high yet.
Today also i saw 1.00, after a WOT in 4/5.
I don't know what to think...
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
Do you have a log file of this ?
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
That's very common with the heat in hot weather and heatsoaked intercooler. Better gas will help but it isn't a miracle. Also keep in mind artificial knock control rise past 5300 RPM.
I changed 3 petrol pumps, but before 4000 rpm it didn't push, it was slow, it lacked aggressiveness, all when I updated the tuning with version 1.9.7. I thought it was petrol because of the very high ignition delay, but when I updated everything went back to the way it was, now it goes like a missele
Im running 1.9.7 just fine. Than may be variation of weather conditions.
SilverArrow
Italy
I don't understand this:
"Also keep in mind artificial knock control rise past 5300 RPM."
do you have the same problem?
kytos
Marcos
Madrid - Spain
Non-SI ecus rise the knock control past that RPM. This is by design, said by @KTuner and Derek Robinson
Knock control will rise dramatically in a non-Si after a WOT run to redline. Combine that with hot ambient temps and seeing it rise to 1.0, although high, isn't shocking.
Knock control is there to protect the engine and will rise under load, with hot temps and/or lower octane gas. It's just dialing back timing as a safety measure.
As long as K.C. drops down and stabilizes I wouldn't worry too much about it. As a general rule, I don't run my car really hard in hot weather due to heat soak.
kytos
Marcos
Madrid - Spain
No risk, is there to protect the engine, tho I think is a bit supid way.
Honda tends to go overboard in terms of reliability. But I agree, I think they could have implemented it a bit better.
varge
George
Greece
I think that kc around 1 is way too much and if it happens more than once in every few wot pulls it means you are pushing it too hard. I run a pretty aggressive custom tune with 232whp and I rarely see more than 0.7
I even have a 60-200km/h log and it hardly raises to .69
@SilverArrow you may upload it here or send me via private message.
kytos
Marcos
Madrid - Spain
That's why im running an upgraded intercooler. Also if not using the A/C and you push the engine hard enough for a few minutes the thermostat/radiator wont open until past 103/5 ÂşC that will cause a little bit more knock.
kytos
Marcos
Madrid - Spain
A 3rd + 4th WOT pull, with warm weather changing gear up to the rev limiter will make it easily land in 0.7 to 1.0 territory..
kytos
Marcos
Madrid - Spain
