alao01
- Mar 17, 2020
- 10
- 107
- 83
- Santa Barbara, CA
- 2016 Honda Civic Ex-L
How would the stage 1 tune compare against a stock accord 2.0?
A little quicker than a manual. Equal to or a little slower than the 10 speed autos. P/W ratios for a Civic w/TSP Stage 1 and a stock 2.0T Accord are about the same.How would the stage 1 tune compare against a stock accord 2.0?
What kind of setup on your settingsPretty damn good mpg with the TSP!
Optimiced tune (afr, response, spark timing) + light throttle (the most important) + efficent engine = Great MPGJust the out of the box TSP tune. I run it on Map 2. I think a couple things are coming into play with my great mpg numbers.
1. With the warmer weather, mpgs generally rise. Part of that is the summer blend gas.
2. Because it's been warm, I purposely tend to stay out of boost more due to heat soak.
Tunes can be really economical if you're light on the throttle.
Wow, I get about 385miles a full tank and average 33mpg. Mainly on map 3 but I noticed map 1 (near stock) seems to use more? Maybe because I have to be a little heavier on the throttle? Gonna try map 2, light throttleJust the out of the box TSP tune. I run it on Map 2. I think a couple things are coming into play with my great mpg numbers.
Version 1.9.8 of what?even though nobody took me into consideration, I wanted to tell you that I have updated to version 1.9.8 and the problem is gone
which problem was it @Andre80 ?even though nobody took me into consideration, I wanted to tell you that I have updated to version 1.9.8 and the problem is gone
I think he meant version 1.0.9.8 of the KTuner software.Version 1.9.8 of what?
