Hactchbacks with upgraded lip?
DRTHVDR
Justin
NJ
2019 CivicX Hatch
Like the title says....looking for hatchbacks with the oem lip replaced. I have a 2019 hatch sport and due to a contruction zone the front lip is a bit loose and was dinged. Looking for options to make the front end more agressive. Pics and or links welcome.
L8apex
Southern Cali
2018 SGP Sport
You have more lip options if you have the LX/Si lower bumper than the Sport lower bumper. I think the Sport will only have a couple that fit under the Sport lip.
Your other option, and this is the route I took when something damaged my Sport lip and grill. I got the OEM LX lower bumper (which is one piece with the lower grill) and the GReddy carbon lip which altogether was about the same price as OEM Sport lip and grill. Getting the LX/Si lower bumper also allows a wider variety of aftermarket lips, or even the HFP one.
Honda Civic 10th gen Hactchbacks with upgraded lip? 11A16297-7486-48C2-86CC-A4CED12289D6
L8apex
Southern Cali
2018 SGP Sport
Also consider, if you’re looking for a more aggressive lip than the stock Sport one, and you damaged your Sport one, your even more likely to damage the more aggressive (lower) lip.
disgraced.fk8
IG: @break_ya_neck_fk7
Drew
Rochester, NY
2021 Boost Blue Type R
absdynamics has one that is flat out amazing. Problem is, last I heard, it was out of stock. It replaces the whole plastic shield that "is" your stock front lip. No drilling, no hacking up your car, just pull bumper, pull stock lip, pull lower grille, and then replace it all with the new stuff. You do have to screw the new lip to the new plastic shield but its easy and doesn't damage the bumper or anything. Here it is on my car. Personally I think it's the best option for hatchback sport, there aren't many....
Honda Civic 10th gen Hactchbacks with upgraded lip? IMG_20200605_201637
DRTHVDR
DRTHVDR
Justin
NJ
2019 CivicX Hatch
You have the link? Maybe I'll consider a preorder.
disgraced.fk8
Drew
Rochester, NY
Here ya go, looks like it's in stock - I would buy this ASAP, it was out of stock for a good bit. I recommend this lip to everyone. It's literally a perfect fit to the OEM push clips, and covers everything up nice. Some of them you remove the shield but the new one doesn't come with a shield... No thanks. They salt the crap out of the roads here.
https://absdynamics.com/collections...en-5d-type-r-style-front-front-lip-unpaint-pp
magshell
Washington
2017 Civic Hatchback ST
disgraced.fk8
Drew
Rochester, NY
Yessir you will need to get it painted! I think I paid like $175, I just did the lip part, left the grille unpainted.
SDSport6MT
San Diego
2018 Civic Sport 6mt
I hit a piece of metal on the freeway at 65mph which cracked the hell out of the front lip and since the sport front lip is $$$$ I just wrapped it in carbon to hide the cracks, not perfect but unless you really look it’s fine for $20.
DRTHVDR
DRTHVDR
Justin
NJ
2019 CivicX Hatch
You use the 4D stuff off Amazon and a heat gun?
SDSport6MT
San Diego
I used the vivid carbon on amazon and a cheapo heat gun I have for other stuff, if it’s your first time wrapping take it slow and leave plenty of extra room for error.
