Randizzle88
- Randy
- Sep 13, 2017
- 13
- 135
- 338
- Chino Hills
- CTR, S2000, CBR Repsol.
ROAD TEST. I tested it in all three modes and felt very good. Car feels very comparable to stock OEM suspension. Maybe a bit stiffer. At high speed and low speed bumps it felt much like factory IMO. I think it a great set up for daily guys that want to keep the factory electronic damper adjustments and want camber. I recommend track guys maybe go up 1 or 2 KG in spring rate.
This conversion kit comes equipped with linear rate Eibach springs, Ground Control bump stops, Ground Control camber plates and of course, our Height Adjuster kit. All of this combined allows you to replace your factory progressive spring, and fixed position top mounts, allowing ride height adjustability and a change in spring rate, as well as alignment adjustment all while retaining your factory equipped electronic adjustable dampers.
