nope happened while drivingHappened at startup? Check out this thread: http://www.civicx.com/threads/strange-sound-at-startup.1304/
So they didn't do anything about it? That's kind of strange. If it is happening only when you are applying the brakes, then it is likely rock/debris that is stuck between the rotors and pads. If it happens while driving and gets worse when speeding up, it could be the same thing, especially if the sound gets worse when applying the brakes.rock or tree branch stuck under car or something. They had no idea
