Grease on Input Shaft Splines?
Add grease to input shaft splines?
  • Total voters
Doc_Mello
2019 CBP Si Coupe
So, when installing a new clutch, do you add a bit of grease to where the input shaft splines meet the clutch hub teeth?
Yes, no, maybe not? šŸ¤·šŸ¼šŸ˜„ The RV6 instructions say to add a very small amount of the Exedy grease to the splines, but I’ve gotten mixed answers, so, let’s see what the community says!
LBP
MI
2020 Civic Si Sedan
Apply a very small amount, place the clutch plate on the splines, slide it a few times and then remove it, and then wipe off any excess that is not on the splines. It's what I've always done, and I've never had an issue with a contaminated clutch or otherwise.
Doc_Mello
Doc_Mello
2019 CBP Si Coupe
Great tip!
  • Like
Reactions: LBP
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
Great tip!
It’s metal to metal and it slides on the shaft so why wouldn’t you I guess???
I mean, I do and probably will again someday.
Engineers, please feel free to crush my inferior intellect with some reason why you wouldn’t. And……. Go!
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
This is the way.
Austin
MI
www.wunderladenracing.com
2018 FK7
Small amount, yes. You definitely don't want to leave them dry, it will wear grooves into the input shaft splines and/or cause irregular engagement/disengagement from the disc not sliding easily.
