CXRs
- May 4, 2020
- 11
- 53
- 8
- Pittsburgh, PA
- Tesla M3P, C6 Z51, VB WRX
Hey all! I'm trying to get everything worked out with the car, and want to be a little more knowledgeable about it before I go messing with tune settings.
I have a ~20% decrease in fuel economy when running the dual starter map and cruising in eco. I don't think I am consciously using the throttle too much more, and I'm keeping to reasonable speeds. The only maintenance items I am aware of needing are CVT fluid change and an air filter(both on the way, AFE dry and Honda OEM). I know the filter can affect power/mpg, but I needed it before the tune and haven't been seeing fuel economy this bad before. LTFT is at about -7%, and has been very slowly climbing since the tune install(maybe 60 miles driven total). I plan on waiting to go messing with the base map until after the filter is in.
I am running the car through moderate city traffic, leaving it on eco using 93, and seeing about 27 mpg. Going through some other threads, it seems like the base maps include a good bit of safety in the commanded AFR, to account for poorly designed intakes. While cruising, I haven't seen the AFR go above 14.7 except on sudden throttle(Eventually I would like to work towards 15.5-16:1 lean cruising.) It typically hovers between 13.5-14.5, which seems a good bit too rich for cruise conditions. I'm hoping the air filter gets me about where I need to be, but considering the fuel trims are deliberately not pulling more fuel, I'm wondering if it will make much of a difference at all.
I realize I've barfed up a whole bunch of info, but I guess what this boils down to is I'm trying to find out if I will have to adjust the tune to pull some fuel out on the stock MAF to achieve the factory fuel economy. Anyone have any insight?
Thank you!
Thank you!
