yhkwok
- Jonathan
- May 2, 2018
- 19
- 681
- 665
- Farmington Utah, Columbus Ohio
- 00 Galant ES 2.4, 18 Sienna XLE (FWD), 18 FK7 ST
- Vehicle Showcase
- 2
2 things I'm researching this weekend,
Glove box damper and Glove box light
As some of you know, the glove box light is available in the 2019 Civics, which I think very likely we can retrofit it into our "older" model, is there anyone confirmed that there's a plug behind just made for that? And maybe even a harness to connect to the light assembly?
I know there're many ways to make that happen, but I'm the kind that will go OEM possible (and reasonable)
Similar thing to the damper, but it's still not available for the 2019 model, and many of us know that it's available in the EDM Civics, I've even check on my own glove box, other than the situation behind the panel left unknown, the glove box itself does have the part where the damper suppose to hook into, and above that on the panel there's this hole that is perfect for the damper arm to stick out.
So 2 questions now, 1) behind the panel would there be enough room to fit that damper in, and 2) which damper could we use? Share with other models like the Odyssey, Accord Crosstour, Clarity, or even the Acura TSX and TL? Or, is there anyone over in Europe would be able to get the part number for the right part? (Or even able to get the part itself?)
Note: mine's a 2018 Hatchback ST, and I was just at the dealer and confirmed the 2018 Sedans have different glove box and the panel above, so this damper thing probably not applicable to Sedans...
