Ghosted - Slow build
Ghosted
D
CA
Civic Hatch Sport
Slowly building a 2018 Hatchback Sport 6MT I picked up in May 2018
Current Mods -
Performance:
PRL Stage 1 intake (replaced with PRL SRI Custom)
Mishimoto Oil Catch Can
BBS 17x8 +38 Wheels wrapped in 225/45/R17 Falken Ziex ZE950
OEM Type R exhaust
Ktuner V2
Suspension & Chassis:
Type R lower subframe brace
Eibach rear sway bar (Whiteline end links) removed
Si rear sway bar
Swift Spec R springs
Front Whiteline endlinks
DC Sport Upper strut bar
Interior:
2020 Type R shifter with Bride shift boot
2022 Si shift knob with Acuity Shift Booth Collar
OEM Type R driver seat
Exterior:
Katana LED H11 Low beam
Alla Yellow LED foglights
Caruse flap
Not installed:
OEM Type R RMM
2020-2021 Type R grill
7” OEM deck (Zed wire harness)
PRL intercooler
PRL Catted Downpipe
Ghosted
D
CA
Civic Hatch Sport
Install PRL stage 1 intake system
Honda Civic 10th gen Ghosted - Slow build {filename}
Ghosted
D
CA
Civic Hatch Sport
Update. Did plasti-dip on my lettering.
Ghosted
D
CA
Civic Hatch Sport
Just pickup some OEM all weather high wall matts.
Ghosted
D
CA
Civic Hatch Sport
Added a Broadway rear view mirror, until I purchase the autodimming mirror.
Honda Civic 10th gen Ghosted - Slow build upload_2018-11-22_21-36-19
Ghosted
D
CA
Civic Hatch Sport
Took me forever, but I finally installed a universal Mishimoto catch can. I had to custom the bracket, because I was cheap and purchased the universal catch can version. I had to get 2 each x 3/8 fittings and 2 x each gates 3/8 hoses.
Honda Civic 10th gen Ghosted - Slow build upload_2018-11-25_21-8-43
Ghosted
D
CA
Civic Hatch Sport
Ahh.. I didn’t catch the date lol. I was going to get one then saw PRL was coming out with one so I’m waiting for that.
No worries. I'll go check it out.
Ghosted
D
CA
Civic Hatch Sport
Installed Mishimoto Catch can on 11/25/18 and at 5600 miles. Today on 01/03/19 with 7600 miles and there is oil in my catch can. Just to report in for others.
Ghosted
D
CA
Civic Hatch Sport
Camera installed. Still need to wire it directly to fuse box when I get a chance.
Update* Had to get new cam. It previous one broke. I picked up an APEMAN Dash Cam C450. Quality seems to be a lot better.
Ghosted
D
CA
Civic Hatch Sport
Pulled the trigger on a Katana LED for my low beams. There are so many LED lighting out there. I picked this one because of the beam pattern. It doesn't scatter high to blind others and maintain same level lighting as OEM halogens. It was also 200% brighter when placed in halogen housing.
Tip: Turn light counter clockwise to remove bulb.
Ghosted
D
CA
Civic Hatch Sport
Installed the OEM Type R shifter. The picture shows type R shifter to the right. While everything was out, I installed the Bride shift boot. I did a test drive and it was a 25-30% improvement. Shifts were more crisp and most of the nochiness went away.
Tip: Hardest part was removing shifter cables from the base. If you look closely enough there is a little nub to lock it in place. Place a small flat head screwdriver to the left of nub and lift lightly while turn shifter cable counter clockwise. Really hard to see it. It took me 30 - 40 mins to figure this out and I found it out by luck.
Ghosted
D
CA
Civic Hatch Sport
Just installed the Si rear sway bar and Type R lower subframe brace. Also took pictures of the Sports (Left) and Si (Right) rear sway. Looks same in picture, but it is a tad bigger. The endlinks are identity for all I can see.
Tip: When putting new sway bar in, make sure the holes connecting to the endlinks are pointing downward.
