Try the second hole on the sway bar. eliminated the clunk on my whiteline bar and end links.After going to a shop to take a look my rear sway bar end links and the noise still remains. I removed the Eibach and put my Si rear sway back on.
Hi @rpereira,Hello @Ghosted, have you addressed the missing brace after installing the FK8 exhaust? I am planning to install this exhaust as well and I am trying to find a solution to avoid running the car with a missing brace.
Thanks for sharing. This is exactly the info I was looking for about the brace and I think I'll do the same.Hi @rpereira,
I just install the exhaust as is (no modification needed) and it will fit fine. You will have an extra hanger on the exhaust, this will not effect the exhaust from making noises or from excess movement. Are you going to install it yourself or have a shop install it for you? Will will not able to reinstall the brace, since the Type R has an extra resonator. I went ahead and got the Type R Brace. Hope that helps.
