Fumoto is having a 20% off sale today and tomorrow!!
TypeSiR
1.5T Civic, Fit, MX-5
You'd want one with a nipple (F106S, F106N) if using the $5 hose kit. Otherwise, oil will just shoot straight out (horizontal!). Unless you get the SX valve with adjustable (angle) valve. The cheapest F106 (without the N or S) doesn't have a nipple.
LSUFANDAN
Dan
Louisiana
2019 Sonic Grey Civic Type R
i think im going to change my own oil so I purchased one. thanks for the coupon. probably could have done it without the valve but looks a lot cleaner lol.
TypeSiR
Which is the appropriate one for the Si? It says that the angle may be off?
The F106S and F106SX should work. Fatherpain didn't have any issue with the F106S and hose kit (see his post above) even though he has a CTR. You can always add the 1/2" or 1" extension for a $6 or $7 if you're not sure. The $5 hose kit is highly recommended.
NapalmEnema
Alex
2017 M2, 2013 X5M, 2019 Type R!!!
The more I read about this setup the less I liked it? Yes it's convenient but there is some logic to the faster flow being better to get particulates out with the oil you're dumping. With the slow flow from the fumoto I'm going to pass on this setup and just do it without. GL those with but I think faster flow is better option than this.
jasonjm
Jason
Pennsylvania
Type-R
I change my oil every 1500 miles or after a hard track day if I hit the temp warning. Don’t like running oil that’s been in the “hot zone”.
This will help with that.
Once a year before winter or (1.5 years) I plan on taking the valve off and doing a flush by having the stock drain bolt in and running some cheapo 0w20 oil for 20 min and then let it full drain warm.
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
2019 Championship white Type R #25133, 09' Civic SI sedan, black 2013 Boss 302 Laguna Seca, 1993 Mustang Cobra, 2004 Mustang Cobra
  • #23
Update : this is still a go for today and tomorrow!:thumbsup:
oak
wayne
so bay
civic type r
Thx for the heads up on the special. Been meaning to get one.
fatherpain
Tom
Thank you. You bring up a good point. Considering picking up a magnetic drain plug to swap for the Fumoto between oil changes every once in awhile, just in case. Maybe annually. ;)
Nitroturtle
WV
2019 PMM CTR, 2006 S2000, 2011 CR-V EX, 2007 Element LX AWD
I use the F106SX on my CTR, as I prefer the ability to position the valve. I have these valves on all 4 of my Hondas and haven't had any issues.
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
  • #29
One important thing to remember about draining the oil, open the fill cap on the valve cover and pull up the dipstick when draining the oil, it will increase the flow tremendously by breaking the vaccum effect on the crankcase.:headbang: This will help pick up the oil flow while using the Fumoto drain valves.
fatherpain
Tom
Ah yes Hermann, that makes a lot of sense. I didn’t do that. Will definitely try that next time!
