Fuel
Howard
Howard
NJ
I have a 2020 lX. What kind of fuel does everyone use?
Does it make a difference?
Howard
Howard
NJ
  • #3
LX sedan
Stick with 87 for your model.
Siiick
Texas
2020 Civic Si, 2019 Corvette Z06, 2017 Fiesta ST
I run Chevron 93 in all my cars.
Howard
Howard
NJ
  • #8
Does the 93 really make a difference vs. 87?
Did anyone answer regarding the empty cut out in the trunk? Is anything missing?
zspeed
Camden County, NJ
If your owner’s manual says 87, use 87. You don’t need anything like 91 or higher since it’ll be useless for a stock engine.
NonyaBisness
Hiding from the Corona
2016 Civic EX-T
fuel TL;DR, Higher Octane fuel is to prevent detonation (igntion of the fuel before the spark and before the piston is at the right point in the stroke)in higher compression (I think it's higher if I remember right) engines (also allows taking out timing), there is no need for it if your engine doesn't require it. A STOCK non-tuned motor doesn't need higher octane then what the manual says, you only need premium if you have a car that calls for premium or are running a tune that needs premium to prevent detonation due to the change in timing.
MaxPower
NJ, USA
2020 Civic Si sedan ABM, 2017 CR-V EX, formerly 2005 Saab 9-2x, 1986 Prelude Si
If anyone else was as confused I was by this apparent non sequitur, it's a reference to this thread.
@OP - apparently there's no definitive answer to that question. Some folks in other countries found a tire pressure gauge (Europe), others found a screwdriver (Latin America). But most owners found nothing at all, just like you. So, no, you probably aren't missing anything.
nizarz
Ottawa, CANADA
2017 Civic LX
I have the Canadian LX. Sticking with anything other that the 87 would be a waste. Confusing because when I lived in the UK, the lowest octane is a 95 and it was recommended to use a higher octane every now and then to clear up any deposits in the engine.
REBELXSi
Señor Member
The octane rating system is different there.
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
Is there any argument to be made re: using 93 since COVID-19 and fuel in the car going 'stale'?
