1.5T Fuel upgrades needed to push higher power on non-Si
Shingo_FK7
Eric
Denver, CO
2019 Honda Civic Hatchback Sport
Hey guys, currently running e30 blend with a custom tune from my local tuner pushing 330 whp and 318 wtq. Tuner said the only reason I couldn’t push more power was the stock bottom end and the lack of fuel. Injectors were pushing themselves to the max when adding more boost past 22 psi on the 27won W2 turbo. I’ve been looking for any advice on how to get around the port injection system PRL offers because buying a motec standalone ECU and an injector driver plus custom fab pieces for mounting the port injection system is more than I’m willing to endeavor into supplying more power. Any advice or knowledge on the subject would be greatly appreciated!
  • Like
Reactions: Myx
More power? With 330 whp/318 wtq, aren't you concerned at all about the hatches "weaker" rods? I think you're at or beyond the safety point.
Shingo_FK7
Shingo_FK7
Eric
Denver, CO
I'm planing on doing the TSP short block engine upgrade very soon, I’m just trying to get ahead of things so I have a plan.
CAPTS
TY
Malaysia
www.facebook.com
10th Gen CivicX CVT->MT
build it before you break it.
don't mean to be rude but it's never a good idea to go too far before building the block. yes you have a very good chance to break yr engine.
maybe you can give vp a call for various types of fuel.
Shingo_FK7
Shingo_FK7
Eric
Denver, CO
Manual or cvt?
Manual transmission and the boost only kicks in around 5,500 rpm and it’s been handling really well. I don’t push it often at all. I’m just waiting on the tax return to finish the engine build.
hobby-man
GTA
You could go for meth injection which is cheapest but carries its own risks. Otherwise you should find an L15B7 head (or put an Si camshaft in your existing head) and get Emans fuel system upgrade.
Shingo_FK7
Shingo_FK7
Eric
Denver, CO
Isn’t his fuel upgrade only compatible with K-tuner?
hobby-man
GTA
Oh I have no idea. Just know it's a potential option. Meth is cheap and easy but on the stock ECU implementing a failsafe is tricky. I haven't worked out a way yet.
EkSean
Sean
2019 PWP FC1
Eman has a fuel system upgrade. Upgraded injectors, hpfp, hard lines and lpfp $1900
xjoshuax89
Josh
Maryland
Daelan from MAPerformance was working on a possible fuel system solution with new fuel pumps late last year iirc but haven't heard from him in regards to any updates.
AFAIK, the only thing out now is really swapping in the Si motor and if you need more than that but want to retain your stock ecu and use ktuner then you need to hit up eman for his upgrade kit.
Chicago
17 civic hb sport
Theres a 2.0T accord swap that works with the Si while retaining stock ECU.
I wonder if it will work with non si
Myx
Delaware
Should simply be able to swap in an Si Ecu as well. This is interesting!
hobby-man
GTA
I think the K20C4 will definitely be the "swap of the future" for this gen once wrecker yards are full of 2.0 accords.
CAPTS
TY
Malaysia
www.facebook.com
5.5k ??? so you have only roughly 1.5k rpm at 22 psi to play with.
dyno chart share would be nice.
