Fuel Line Recommendations
Adova
Shawn
Coral Springs, Florida
2021 CTR
I am hooking up my Flex Fuel kit and a Radium filter. I want to run all new PTFE from the Flex Fuel to the filter and from the filter to the XDI Pump. Being new to AN fittings and fuel line, can anyone recommend a particular brand? Also, what ID should the line be - I am seeing 5/16 and 3/8 options. I am also thinking this should all be 6AN, correct?
speedyserg
Sergio
Long Beach
2021 Type R
They make several versions depending on what flex fuel kit you are running but this is what I'm running
https://www.jsrengines.com/product/prl-fk8-cv2-ptfe-upgraded-flex-fuel-line
Adova
Adova
Shawn
2021 CTR
ToofHurts
South Florida
'19 CW CTR
I used Redhorse Performance for my PTFE lines and all of the 6AN fittings. Bought direct from website. Not a single issue. No leaks. They are NHRA approved (if that means anything)
ToofHurts
South Florida
'19 CW CTR
Also the 5/16 and 3/8 issue is only for the AN fitting that attaches to the factory hardline and the fitting that attaches to the HPFP. Everything else is just straight 6AN.
