Dario1101
- Dario
- Jun 6, 2017
- 3
- 253
- 90
- Miramar, Florida
- 2021 Honda Civic Hatchback Sport
That sounds great man! I wish I had some visual aid to go along with it, and some torque specs haha. How much do those fuel injectors even cost?1. Remove all the connections on the manifold, as well as hoses, for the hoses pick the easiest side to Disconnect from.
2. Disconnect the 4 bolts on the throttle body. Disconnect the 3 bolts on top of the manifold, 2 on the bottom. Pull the manifold off.
3.Remove the gard on the end of the fuel rail, 2 bolts. Unclip the injector wires.
4. Disconnect fuel line to the rail, remove the rail bolts x2 for each injector. Pull the rail off, you do not need to Disconnect the rail pressure sensor on the end. You can then bring the rail up ontop of the motor to service the injectors.
5. Throw it all back together.
