- Feb 15, 2017
- 108
- 4,710
- 4,874
- USA
- 2019 Accord Sport 2.0T, 2017 Si Sedan (Sold), 2017 Sport Hatchback (Sold)
- Vehicle Showcase
These are coming off the car tomorrow so I wanted to go ahead and put this out there. I am selling my Brembo BBK. They will fit any 10th gen other than the Type R. They bolt straight on and do not require any drilling or modifications to anything. This set is for the front of the vehicle only. I've yet to find any upgrades available for the rear due to the electronic parking brake. I am upgrading to a 6 piston setup.
The set includes the following:
I will add more photos after they come off the car tomorrow evening.
- (2) Brembo 4 Piston Calipers
- (2) 12.9" Cross-drilled brake rotors
- (2) Pair of Hawk HPS Brake pads (these use the same pads as the Type R, Sti, etc)
- The calipers have about 15,000 miles on them since they were rebuilt and powdercoated. They were not abused but light scratches and other marks are to be expected.
- The rotors have about 15,000 miles on them as well. I would recommend having them turned if you want to re-use them, or I can get you a new pair for under $150.
- These calipers are much larger than the OEM setup. If you want to use OEM wheels, you can expect to need a 20mm wheel spacer. I currently have them under a set of aftermarket 8.5" wide wheels with a +35 offset, in addition to a 3mm spacer for a bit of breathing room. Wheel fitment is going to depend on how concave the wheels are, spoke thickness, etc.
- Your OEM brake lines are compatible with these calipers.
- No other supporting modifications are required. (brake master cylinder, etc)
