Front tow hook (strap) solution for 2020+, no bumper modification required
pwrofdrm
Evan
NY
2020 CW CTR
I needed a front tow point but wasn’t too keen on the idea of hacking up the front bumper garnish to make it work. After some research I came up with a solution, so thought I’d share for anyone else with a 2020 with this need.
I ordered the EVS Tuning Front Tow Hook Adapter from Evasive Motorsports. $195
https://www.evasivemotorsports.com/...tow-hook-adapter-rev2-honda-civic-type-r-fk8/
I ordered a tow strap, there are many many options on the market from multiple sources. Just make sure you get a ‘real’ one that’s actually rated for towing and not one built for aesthetic purposes. I purchased a Grayston brand one, but Sabelt makes a nice one too. $15-$25
I then got a bolt to fasten the tow strap to the tow hook adapter from Belmetric. SKU no. Is BH22X50FYLW, 50mm Length. $7.36
https://belmetric.com/m22x2-5-coarse-din-931-933-hex-bolts-10-9/?sku=BH22X50FYLW
With that, I was able to attach the tow hook adapter and tow strap and then snake the tow strap through the slotted opening in the factory garnish.
Honda Civic 10th gen Front tow hook (strap) solution for 2020+, no bumper modification required C2041EF3-7461-481A-99BB-A43953C59AEA
Honda Civic 10th gen Front tow hook (strap) solution for 2020+, no bumper modification required 1FD6CCD9-37F0-49E4-BB1B-B48CB7875687
Honda Civic 10th gen Front tow hook (strap) solution for 2020+, no bumper modification required BFE560C9-ED71-49E0-95C9-633A44D27257
Honda Civic 10th gen Front tow hook (strap) solution for 2020+, no bumper modification required 9A82F74A-5209-48F9-A761-48E6C085B63D
Honda Civic 10th gen Front tow hook (strap) solution for 2020+, no bumper modification required B5478984-9764-44EB-8D42-EAE0CF8BB1EA
keller
Somewhere south
2019 CBP Si coupe, 2021 SGP Type R
Wow, I was looking for a solution that mounted on the passenger side (because of honda sensing) and required no modification. This is perfect! Already ordered mine =)
Thank you
Yuhctr
El Monte, California
2021 Honda Civic type r
have you gotten towed with that set up yet? wondering if itll damage anything if theres upwards force while being towed
Brandondan1
Brandon
Dallas, TX
2018 CTR, 91 Civic Si
Does the wunderladen part only work on the driver's side?
If so, you would have to cut the grill garnish to pass through, because USDM cars only have a hole on the passenger side.
pwrofdrm
pwrofdrm
Evan
NY
2020 CW CTR
No, thankfully, but that is something I thought of and I did check to make sure that wouldn’t be the case. Couldn’t replicate a situation where it could be.
