Front Left Steering Knuckle
ez12a
CA
18 CW Type R
broken ball joint? Either way should be covered under factory 3yr/36k mile warranty or extended warranty.
zspeed
Camden County, NJ
I would suggest that you buy the part online and have another shop put it in for you.
Learn2turn
Christopher
Rio Rancho NM
'79 Toyota Longbed PU, '95 (Drift Toy) Miata, '05 Tuned Gran Prix White S2000, '19 Championship White C-Type R
Did anything happen before you noticed it, impacts, etc?
Learn2turn
Christopher
Rio Rancho NM
What are they saying is causing the "looseness"?
Learn2turn
Christopher
Rio Rancho NM
Damn, It has to be available somewhere though.
FK8Guy
VA
CTR FK8
take off the knuckle and have napa work shop in your area use a 10 ton press to install the new ball joint. Pretty sure might need an alightenment . Do not drive it hard or you might cause more suspension damage if your tire collapses , broken axle maybe
No real reason to mod the type R more unless you are getting hondata. Just my opinion.
Thats why you spent 10k more than a SI.
But since you made it obvious with your mods you will have to suck it up and spend the money to get your car fixed right. If you do it my way you can save about 650
Learn2turn
Christopher
Rio Rancho NM
Fixed??????
Gotta say more than that...
