cataclysmseng
my front bumper not align. bumper lower than fender. how to fix it..can.post urs..
They just ship the crappy Canadian made ones south to the US. We keep the good ones up herehow come urs so nice
my one very worst compare to ursThey just ship the crappy Canadian made ones south to the US. We keep the good ones up here
I did notice in my pics there's a bit of a gap difference between the bumper cover and headlight housing.
Not sure how they mount but maybe they just need to be removed and aligned better before it's snapped in.my one very worst compare to urs
I had a similar alignment issue with my 2017 EX, built in Indiana (2/17). driver's side was not lower but popped out. Two polymer mounts are present to hold this bumper skin corner, a short mounting bracket along the fender and large mounting bracket under the headlight unit. I tried to push the section in but only popped out over time. Had to pull the bumper cover's driver side away from brackets/clips, replaced the side plastic mounting bracket, but couldn't replace the mount under the headlight unit, too cumbersome to remove the headlight unit and three bolts holding the bracket. Snapped the bumper cover into the new side clip mount and has been holding tight.Was this resolved?
How much would labor would be for doing something like this for just aligning the back bumper.I had a similar alignment issue with my 2017 EX, built in Indiana (2/17). driver's side was not lower but popped out. Two polymer mounts are present to hold this bumper skin corner, a short mounting bracket along the fender and large mounting bracket under the headlight unit. I tried to push the section in but only popped out over time. Had to pull the bumper cover's driver side away from brackets/clips, replaced the side plastic mounting bracket, but couldn't replace the mount under the headlight unit, too cumbersome to remove the headlight unit and three bolts holding the bracket. Snapped the bumper cover into the new side clip mount and has been holding tight.
Not sure on the number of the pop fasteners/bolts/screws holding the rear bumper cover, but the front took about 1 hour, to remove 80% of the cover, install the new bracket section and re-fasten.How much would labor would be for doing something like this for just aligning the back bumper.
